ECU question
Old May 18, 2003 | 08:56 PM
brownman72000's Avatar
Default ECU question
I need to pass emission and currently have kenjis p28 in my car but....will a 1993 dohc stock intergra ECU fit in my car and work just so i can use that to pass? If not, what other models will fit in my car so i can pass the test? Thanks!
Old May 18, 2003 | 10:42 PM
Unsung's Avatar
Default Re: ECU question (brownman72000)
If you have a B16a/b or a B18c5, it should work. Anything with a PR3 head is my guess.
Old May 18, 2003 | 11:00 PM
iH8RICERZ's Avatar
Default Re: ECU question (Unsung EM1)
if you have a 93 GSR motor, then you will need a p61
Old May 19, 2003 | 03:42 AM
kenji's Avatar
25 Year Member
Yes, you can use your 1993 DOHC ECU and it should pass.
If the ref in your state is very strict and looks at the ECU (highly unlikely) then it would fail the visual.
As long as your car is not throwing codes and passes the sniff test you should be fine.
Or you can use your stock ECU or any other '92-'95 DOHC VTEC ECU (assuming you are using your OBD2 to OBD1 ECU conversion harness) and it should pass.
Good luck.
-kenji
SCb18b1Civic
Oct 31, 2011 03:52 PM
Convoy
Nov 17, 2003 01:33 PM
brownman72000
Jul 11, 2003 08:01 AM
