first signs
Old May 18, 2003 | 08:38 PM
green98civic's Avatar
Default first signs
my crx is leaking oil everywhere i leave the car at. also the oil light comes on when i come to a complete stop at a light. also it takes a little bit to start the car. are these the first signs of the engine going???
Old May 18, 2003 | 08:51 PM
bfrank81's Avatar
Default Re: first signs (green98civic)
You have to find out were the oil is leaking from. Once mine was doing the same thing. I crawled under the car and it was the freaken drain plug. I went to Pep Boys and bought a new one. Hasn't leaked since.
Old May 18, 2003 | 08:54 PM
TRE_'s Avatar
check your oil level ASAP. you're probally raelly low on oil, and if so add some as soon as you can. jack up the car and try to figure out where the oil is coming from, it could be something like the oil pan gasket or maybe the rear main seal. try to save your motor while you still can.
Old May 18, 2003 | 10:17 PM
capbyrd's Avatar
like frank said, i had a similar problem that turned out to be the drain plug. check where the oil is comin from first and then fix that. if it still happens, then diagnose again till you get it right
NteGSR2o9
Oct 13, 2009 10:18 PM
builtek9
May 3, 2007 04:19 AM
soundFX
Jan 7, 2007 05:53 PM
ludecrasy87
Oct 27, 2006 02:07 PM
SIMSSEGA
Apr 2, 2006 11:04 PM
