clutch pedal is stuck to the floor HELP!
Old May 18, 2003 | 08:36 PM
lude97dude's Avatar
Default clutch pedal is stuck to the floor HELP!
After I took out the slave cylinder I accidently stepped on the clutch pedal to shift into reverse. Now the clutch pedal is stuck to the floor! Can somebody please tell me how to fix this ?? Greatly Appreciated!!
Old May 18, 2003 | 08:39 PM
Prelude Vtec 23's Avatar
Default Re: clutch pedal is stuck to the floor HELP! (lude97dude)
Did you already install the slave cylinder? Afterwards you need to bleed the clutch.
Old May 18, 2003 | 08:52 PM
Cottonwoodz's Avatar
Pull up on the clutch pedal..
Old May 18, 2003 | 08:55 PM
dvp95's Avatar
Default Re: clutch pedal is stuck to the floor HELP! (Cottonwoodz)
Just bleed it and you will be fine!
Old May 18, 2003 | 08:56 PM
Jago's Avatar
Default Re: clutch pedal is stuck to the floor HELP! (Prelude Vtec 23)
look at the slave cylinder and see if you can push the rod back into the cylinder.
you probably didn't have the cylinder lined up with the clutch release lever
correctly and when you steped on the clutch it forced the cylinder all the way out.
It's the same as if you step on the brake pedal with the calapers taken off the
rotor, you will never be able to get them back apart. If this is the case you'll
need a new slave cylinder.
Old May 18, 2003 | 11:18 PM
lude97dude's Avatar
Default Re: clutch pedal is stuck to the floor HELP! (Jago)
ok i got a new slave cylinder at kragen today so now do i just install it then bleed it and it will release? i'll be working on this on the morning.. thanks guys!
Old May 19, 2003 | 07:16 AM
Jago's Avatar
make sure you line up the little ball so it sits inside the dome shape
on the clutch release. you can feel it with your finger.
Old May 19, 2003 | 07:49 AM
DSGB.'s Avatar
Dirty Bird
It could take anywhere for 10-45 mins to bleed it with 2 people.
Old May 19, 2003 | 08:56 AM
dvp95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude97dude &raquo;</TD></TR><TR><TD CLASS="quote">ok i got a new slave cylinder at kragen today so now do i just install it then bleed it and it will release? i'll be working on this on the morning.. thanks guys!</TD></TR></TABLE>
It will be back to normal, just pump the clutch with your hands while someone works the other end to make sure there are no bubbles getting in.
Old May 19, 2003 | 08:59 AM
Mike95lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">Pull up on the clutch pedal.. </TD></TR></TABLE>
Yep...It happened to me to before. Just pull up on the clutch pedal hard.
Old May 19, 2003 | 02:32 PM
lude97dude's Avatar
Default Re: clutch pedal is stuck to the floor HELP! (Mike95lude)
ok now should I pull on the clutch pedal real hard or bleed the clutch or pull on it real hard while bleeding?? gah now i'm confused.
PaulMc
May 18, 2014 05:04 PM
gooblinn258
Jan 18, 2014 05:02 PM
RDAYA0
Dec 14, 2006 05:31 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
vteg
Aug 1, 2002 03:10 PM
