Is it my Idle Air Control Valve?
Old May 18, 2003 | 07:32 PM
Hondaaccordvtec's Avatar
Default Is it my Idle Air Control Valve?
Hi guys,
Done many searches and read many pages of text. I have any idea but would like some additional input/feedback. I have a surging idle from 1000 -1500 rpm, constantly bounces back and forth. I have done the following: replaced Fast Idle Thermo Valve, checked TPS voltage - which is accurate, checked for vacuum leaks - no leaks, checked intake manifold gasket - no leaks. Now, when I disconnect my Idle Air Control Valve sensor, the car idles perfectly. IS this really the cuplrit to my surging idle? I don't want to have to pay around $200 bones for a new one. Is there anyway to open this up and take a look inside and possibly fix this?
Any feedback or suggestions you have would be greatly appreciated.
Thank you for your time.
Old May 18, 2003 | 07:41 PM
Prelude Vtec 23's Avatar
Default Re: Is it my Idle Air Control Valve? (Hondaaccordvtec)
There was a post about this about a month or two ago, the guy just used some carb cleaner and cleaned the screen out and his car idled fine again. I cant find the link for it, does anybody else know what I am talking about or have that link?
Old May 19, 2003 | 03:36 PM
Default Re: Is it my Idle Air Control Valve? (Prelude Vtec 23)
Can someone tell me if I un-hook the IACV sensor plug, is the engine supposed to idle still or should the engine die?
Old May 19, 2003 | 04:57 PM
Sticky Tires's Avatar
* B A N N E D *
http://www.preludeonline.com/s...g+IAC
Old May 19, 2003 | 04:59 PM
ejectseat's Avatar
Default Re: Is it my Idle Air Control Valve? (00 typeSH)
take it off - make a block off plate - connect the two wires on the plug and it will close the circuit and no CEL. Mine works perfectly now.
Old May 19, 2003 | 06:13 PM
Casual Gcode1's Avatar
Default Re: Is it my Idle Air Control Valve? (ejectseat)
http://preludeonline.com/showt...10161
self_made
Apr 10, 2021 02:25 AM
95gsr@530
May 13, 2019 10:43 AM
stuckinmud
Aug 14, 2009 08:32 AM
troyport
Classic Hondas
May 28, 2009 09:06 AM
jaskuloski97sh
Sep 22, 2007 04:36 PM
