someone please help with steering column
yeah ui notice that when i kock the heght of the steering cloumn it still shakes a little if i move it up and down and when i lock the steering wheel it moves the ignition key thingy. still alittle bit. can someone please help me.
check under the steering column for an white round plastic hard bushing where you have the bracket....it may have slide down the steering column...just unbolt the two bolts on the bracket slide it back in place and wrap it with some good old duck tape and bolt the bracket back up and you should be good to go!!!!
