Fuel Trim/Map Low input malfunction P170/P107 Codes
Old May 18, 2003 | 05:14 PM
ELSpool's Avatar
Default Fuel Trim/Map Low input malfunction P170/P107 Codes
Here is my set up first.
D16Y8 OBDII (99)
T3/TO4E (9 psi)
S-AFC
Tech Edge Wideband O2
450 cc Talon Injectors (1997 Blue Tops)
B&M FPR
Water To Air IC
I keep getting a low input malfuction code with the afc set at anything higher than
-34 ie. -35 and up, but with that set for my cruze, the fuel trim code comes up because the long/short term trim on the ECU max out and sets the fuel trim malfuction. I can tell all of this because my mechanic has a sanp-on diagnostic code reader. My base pressure is as low as I can go to help trim out, so what else can bedone?
Thanks!
Old May 18, 2003 | 06:20 PM
Leb_CRX's Avatar
Default Re: Fuel Trim/Map Low input malfunction P170/P107 Codes (HiRolla)
TTT
|eb_CRX
JDMB20TDA
Sep 11, 2007 02:54 PM
jdmBOMEXsi
16
Apr 13, 2005 06:51 AM
Leviata-N
Oct 8, 2004 07:01 AM
Mr. 1582
Nov 8, 2003 04:23 PM
jetpilot
Sep 4, 2003 08:37 PM
