Clicks while turning
Old May 18, 2003 | 04:55 PM
MLogan's Avatar
Default Clicks while turning
Im almost positive the problem is my cv joints. when i turn either way, there is a clicking noise. It started only when i turned one way and now clicks when i steer either way. This has been happening for a long time and im just getting around to fixing it.
My question is what do i have to replace? Just the axles? And I need a 36 mm socket correct?
Old May 18, 2003 | 05:15 PM
Frosty_spl's Avatar
Default Re: Clicks while turning (MLogan)
yes.
Old May 18, 2003 | 05:17 PM
JDMy0's Avatar
141.217.174.219
you answered ur own question
Old May 18, 2003 | 06:24 PM
Turbo Powa's Avatar
Default Re: Clicks while turning (Ub4rUser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ub4rUser &raquo;</TD></TR><TR><TD CLASS="quote">you answered ur own question </TD></TR></TABLE>
Old May 18, 2003 | 08:19 PM
all stock's Avatar
and 36 and a cheater bar. u won't be able to get that off with just hand tools.
i want an impact gun...
Old May 19, 2003 | 12:14 PM
MLogan's Avatar
Default Re: Clicks while turning (Frosty_SPL)
I usually answer my own questions after i read so many threads, thanks
Old May 19, 2003 | 06:07 PM
MLogan's Avatar
Default Re: Clicks while turning (all stock)
One more question, it is a 36 mm right? I went to sears and they didnt have it, have to order from catalog i guess.
I just looked at a How-to post by Tom ( https://honda-tech.com/zerothread?id=382564) and he says a 32mm. Is it different for the ITR axles?
Old May 19, 2003 | 06:36 PM
Civic_Pilot's Avatar
my car does the same thing and it's only a few months old. it's sittin at the dealer right now. what causes this? what are cv joints?
Old May 19, 2003 | 06:43 PM
The HamsterBall's Avatar
my god. this guy's the best. not only does he use the search feature BEFORE asking a question, but he actually finds something and helps himself out. And not only that, he doublechecks just to make sure. What a good post. Not like those other idiots who are like "How much does a civic EX weigh?" without looking at "zerosearch". GOOD JOB!
Old May 19, 2003 | 07:05 PM
b16ahybrid's Avatar
Default Re: Clicks while turning (Civic_Pilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_Pilot &raquo;</TD></TR><TR><TD CLASS="quote">my car does the same thing and it's only a few months old. it's sittin at the dealer right now. what causes this? what are cv joints?</TD></TR></TABLE>
cv joint = constant velocity joint... or your axles.
Common causes of failure include old age, torn boots that cover the joint. When torn the grease escapes and debris from the road can get in causing excessive wear. Also another known killer of cv joints is too much traction. I.E lots of power (in the form of turbo,sc,n20,etc) and slicks usually spell death for stock axles.
Old May 19, 2003 | 07:12 PM
Default Re: Clicks while turning (b16ahybrid)
thanks.
Old May 20, 2003 | 04:22 PM
Chris y0!'s Avatar
32mm
Old May 20, 2003 | 04:29 PM
sshaikh01's Avatar
I'm touched the axle nut twice.
Once on a 96 civic, and once on a 90 teg.
If you can't find a 36mm.
Go to auto zone, and get yourself a 1/4 size socket.
Thats what i did, and it worked like a charm.
note: YOu will need a long as azz bar, or something like that, you will NEVER ever get it to open with just your average wrech. Trust me i know
Old May 20, 2003 | 11:23 PM
AllMotorHB's Avatar
Default Re: Clicks while turning (sshaikh01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">I'm touched the axle nut twice.
note: YOu will need a long as azz bar, or something like that, you will NEVER ever get it to open with just your average wrech. Trust me i know </TD></TR></TABLE>
On my civic it's a 32mm. I always thought they were all 32mm but a couple of you guys are saying 36mm.
Old May 20, 2003 | 11:26 PM
AllMotorHB's Avatar
O yea alittle off topic maybe, but what did you guys use to punch in the axle nut after you torqued it down. I tried a flat head screw driver but that didn't work out so i'm just driving around with it torqued down. Was gonna go out and buy a center punch but decided to ask you guys first.
Old May 21, 2003 | 04:02 PM
sshaikh01's Avatar
Default Re: Clicks while turning (AllMotorHB)
flathead and a hammer worked for me both times.
Old May 22, 2003 | 01:08 PM
MLogan's Avatar
Maybe i will just buy the 32 and if not right, just return it. Got the huge breaker bar, hope that will work.
MLogan's Avatar
Default Re: (HamsterBall)
I try.
aw94teg
May 25, 2006 07:24 PM
lv6l
Oct 6, 2005 01:27 AM
danielm3
Welding / Fabrication
19
Oct 4, 2005 12:09 AM
NeedsMoSpeed
Mar 21, 2005 09:49 AM
vaporboy12
Mar 20, 2005 08:36 AM
