what kind of plugs should i use w/a turbo setup?
Old May 18, 2003 | 02:55 PM
crx1856's Avatar
Default what kind of plugs should i use w/a turbo setup?
just wondering what plugs i should use w/revhard 2c turbo setup?
Old May 18, 2003 | 03:01 PM
Gravy's Avatar
Default Re: what kind of plugs should i use w/a turbo setup? (crx1856)
ngk #7. i think the part number is 4091
Old May 18, 2003 | 03:07 PM
Jared's Avatar
Default Re: what kind of plugs should i use w/a turbo setup? (GRTechnologies)
how much boost?
Old May 18, 2003 | 03:46 PM
crx1856's Avatar
Default Re: what kind of plugs should i use w/a turbo setup? (Jared)
stock for now(7lbs) but more later on.
Old May 20, 2003 | 06:40 AM
gsrcivict's Avatar
stock number on the bkr-7e is 1283
Old May 20, 2003 | 06:47 AM
PrecisionH23a's Avatar
Default Re: what kind of plugs should i use w/a turbo setup? (gsrcivict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivict &raquo;</TD></TR><TR><TD CLASS="quote">stock number on the bkr-7e is 1283</TD></TR></TABLE>
that is correct. bkr 7e-11's actually run about a .030-.032 gap.
Old May 20, 2003 | 07:05 AM
silverEH2's Avatar
Default Re: what kind of plugs should i use w/a turbo setup? (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">
that is correct. bkr 7e-11's actually run about a .030-.032 gap.</TD></TR></TABLE>
the bkr 7e-11's are pre-gaped to .044 so i say just get the bkr 7e's part number 6097...they are not pre-gaped but they come usually between .030- .035 so you dont have to bend the post as much
Old May 20, 2003 | 07:17 AM
Default Re: what kind of plugs should i use w/a turbo setup? (silverEH2)
i learn something new each day
Rus1an
Apr 27, 2006 12:22 PM
1SlowSi
May 23, 2005 06:35 PM
WEldin4fun
May 11, 2005 08:00 PM
99integralsturbo
Sep 9, 2003 12:58 PM
Vtec92Civic
Aug 23, 2003 07:00 AM
