Cutting into ignition wire, which wire is it ?
Old May 18, 2003 | 01:46 PM
RCautoworks's Avatar
Default Cutting into ignition wire, which wire is it ?
I need to splice into one for my gauges, which one did you guys cut into ? What color was it ? Here is a pic.
Old May 18, 2003 | 02:13 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: Cutting into ignition wire, which wire is it ? (90blackcrx)
i think its the black wire with a yellow stripe, its like a 12 guage wire. I spliced into it for a kill switch.
Old May 18, 2003 | 02:16 PM
jasonb's Avatar
I'd like to know as well
Old May 18, 2003 | 05:40 PM
keithv's Avatar
Default Re: Cutting into ignition wire, which wire is it ? (jasonb)
i use a spare fuse box 12V connection that is only powered on when the ignition is on. i forgot the locations exact numbers but its up at the top of the under dash fuse box.
Old May 18, 2003 | 05:56 PM
MADEINIRAQ's Avatar
Default Re: Cutting into ignition wire, which wire is it ? (keithv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">i use a spare fuse box 12V connection that is only powered on when the ignition is on. i forgot the locations exact numbers but its up at the top of the under dash fuse box.
what he said
there are 2 female blade connectors on the fuse box towards the top.. 1 is ignition power 1 is light power.
GOOD LUCK
(760)doogie
Jul 9, 2007 04:20 PM
Boarderx192
Dec 5, 2005 07:35 AM
phoshizzle88
Sep 12, 2005 02:27 PM
andyhoiho
May 29, 2004 07:58 AM
