what grade of (RACE FUEL) are you running???
Old May 18, 2003 | 12:59 PM
allmotorb20vtec's Avatar
Default what grade of (RACE FUEL) are you running???
just wanted some inputs on what type of fuel should i runat the track in a mildly built crvtec set up with 12-5-1 je pistons??
Old May 18, 2003 | 01:44 PM
Suprdave's Avatar
Default Re: what grade of (RACE FUEL) are you running??? (allmotorb20vtec)
Why can't yu run 93 octane on that setup?
Suprdave
Old May 18, 2003 | 01:48 PM
TREVER's Avatar
what was it tuned on?
Old May 18, 2003 | 02:45 PM
1 2 NV's Avatar
my race fuel is chevron 92 supreme 92 octane
Old May 18, 2003 | 03:02 PM
Dual Cams's Avatar
Default Re: what grade of (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Why can't yu run 93 octane on that setup?
Suprdave</TD></TR></TABLE>
i want to know why too
Old May 18, 2003 | 04:40 PM
Default Re: what grade of (Dual Cams)
we are running 93 octane but im wonder if 110 leadedrace fuel will cause any fuel injection problems in the longrun.
but as for race gas ive been using 100 octane unleaded but its very hard to get
cause the gas station no longer has 100 oct unleaded, only 110 leaded.
Old May 18, 2003 | 04:44 PM
1 2 NV's Avatar
Default Re: what grade of (allmotorb20vtec)
id b more worried about it screwing up ur O2 sensor than running odd. that is if u are running an O2 sensor still.
Old May 18, 2003 | 05:44 PM
boosted3g's Avatar
Default Re: what grade of (hondaatwsu)
I run c12 on the street and c16 at the track. Its not cheap but id liek to keep my motor in one peice. I also ran this with the factory 02 which is the only thing you are going to damage. I did about 8k last year with no problems.
Old May 18, 2003 | 06:26 PM
SlowAssStang's Avatar
i use NOS/VP fuel (about 114octane) for the track, 93 on the street unless im gonna be on the bottle, then i run either 100oct unleaded and pull out a little more timing, or go get some C12.
spockeg
Sep 1, 2006 04:26 PM
vr6chris
Jan 10, 2005 07:37 AM
chet
Sep 23, 2003 04:44 PM
havok hybrid
Sep 29, 2002 12:05 AM
88CRXHybrid
May 28, 2002 07:22 PM
