Stretched head bolts....
Old May 18, 2003 | 11:59 AM
jdm-spec-eg's Avatar
Default Stretched head bolts....
Just out of curiousity, what would happen if you installed stock head bolts that were stretched beyond spec?
Old May 18, 2003 | 01:04 PM
CW-ITR-329's Avatar
Default Re: Stretched head bolts.... (jdm-spec-eg)
They would probably snap, and then you would have to drill it out...
Old May 18, 2003 | 01:46 PM
Default Re: Stretched head bolts.... (CW-ITR-329)
Im just curious if it would cause an imperfect torque reading? I torqued a head with 30,xxxkms on it, to a new rebuilt bottom end. Its leaking coolant into the #1,#3,and #4 cylinders. #1 and #4 are really bad.
Both the block and head were decked. But I reused the headbolts and I am wondering if thats my culprit.
Old May 18, 2003 | 02:44 PM
Evs-One's Avatar
Solbros Owns Me
did you use a new oe spec gasket???
did you spray copper gasket sealer on it??
did you torque in order??
Old May 18, 2003 | 03:11 PM
MackSpeed-616's Avatar
dood.. bolts are 10 bucks a pop.. just replace em
Old May 18, 2003 | 03:21 PM
Default Re: Stretched head bolts.... (Emerika)
No I didnt use the copper spray..
I did and will always use a new OEM head gasket.
This is the third time these bolts have been used and it looks like I will be needing a new head gasket and ARP head studs.
Old May 18, 2003 | 06:13 PM
Smitdog's Avatar
When in doubt, just replace with new ones......
Old May 19, 2003 | 02:56 PM
Chubz's Avatar
do yourself a favor and get the arp head studs, and use copper spray and make sure the gasket was on the right way
Old May 19, 2003 | 03:04 PM
95gsr's Avatar
Default Re: Stretched head bolts.... (DeadWrong)
how can you tell if the gasket is in the right way, isn't it the work up is suppose to be seen. and where do you spry copper spray thanks
Luis
Old May 22, 2003 | 02:00 PM
Chubz's Avatar
Default Re: Stretched head bolts.... (95gsr)
search is your friend
twocross
Feb 23, 2011 03:07 PM
CYBERBASS
Honda Civic (2001 - 2005)
Apr 27, 2010 07:11 AM
CRXed
Aug 23, 2009 08:50 PM
memorybox
Oct 21, 2006 09:02 PM
petrv
Apr 12, 2004 12:30 PM
