Help, Neon Lights Won't Work
Old May 18, 2003 | 09:32 AM
blitz-integra's Avatar
Default Help, Neon Lights Won't Work
I have red underbody neons that were working fine til tonight. For some reason when i flip the switch, they flash on then don't glow. I know im getting power from the battery because my switch is illuminated. And im PROBABLY (please correct me if im wrong) getting current through the wires cuz they flash. So can anybody tell me whats wrong? I checked all the connections and they seem to be fine. And the fuse is not blown either. could it be the tubes, cuz they are brand new. I also have the neons running to the battery terminal in my engines fuse box if that helps any. I redid all the connections under the hood and they were fine. All the other ones looked fine too. Any help would be great and please don't flame cuz i have neons they are for shows haha( go ahead and flame as long as you help me)
Old May 18, 2003 | 09:39 AM
B U N M A N G O's Avatar
Default Re: Help, Neon Lights Won't Work (blitz-integra)
haha good thing you're ready to get flamed j/k... I would try using one of those wire testers to make sure you're getting power to where you think it's going
Old May 18, 2003 | 09:41 AM
Rory Breaker's Avatar
Dont flame him...to each their own. If you cant provide help, dont post.
Im not sure other than the tubes. Im not too good with wiring, nor am I famliar with the lights at all. Have you tried hooking up a bulb to the wires powering the tubes? If the bulb illuminates, theres your answer.
typeR#0427's Avatar
Default Re: Help, Neon Lights Won't Work (bunmango)
Maybe now would be a good time to take them off and invest your time in something else. J/K Try looking at all of your connections. Something just might be loose.
Old May 18, 2003 | 09:51 AM
im gonna check the connections for the tubes later tonight. I was just seeing what were some other things that could be wrong.
Old May 18, 2003 | 12:40 PM
TerribleOne's Avatar
Default Re: (blitz-integra)
does it flash when your driving, that might be the connection rattleing and losing current, but if you checked all the wires for current and they all seem fine its got to be the connection to the bulbs, did you have them put on or did you do it?
Old May 18, 2003 | 03:17 PM
whenever i flip the switch is blinks. im gonna re connect all the wires with butt connectors and see what happens. Anymore suggestions?
Old May 18, 2003 | 03:24 PM
B16OnTop's Avatar
ask the appearance guys im sure they would be more then glad to help
Old May 18, 2003 | 03:25 PM
The-LS's Avatar
take as a sign from GOD, its not meant to be. j/k You try the security forum section. I'm sure they would have more knowledge of the electrical side of things.
Old May 18, 2003 | 05:42 PM
IntegraBoy04's Avatar
Default Re: (SilverDc2)
Check the actual tubes. If there is any crack on them at all, they won't work. This happened to mine. I think it was a sign from God saying, Take that **** off. But check that out.
Old May 18, 2003 | 08:07 PM
JforJonathan's Avatar
check all your ground connections
Old May 18, 2003 | 08:11 PM
maxxdout's Avatar
Default Re: Help, Neon Lights Won't Work (Dj Villain)
What system are you using? I have installed a few systems for friends, mainly StreetGlow, but anyways.... This sounds to be to be a transformer box problem. If you have changed nothing, i mean havnt hit anything, bumped a tube, or loose ground, then this flicker at first turn on sounds like the transformer box to me.
I also think that STreetglow has a lifetime warantee or something like that on there transformer boxes. Im sure other companies would have something similar.
Good luck
mattchew_2124
12
Feb 13, 2014 11:34 AM
Dave1821
Apr 18, 2009 11:27 AM
j_kevin_ca
Jun 25, 2007 11:00 AM
clg03c
Jun 27, 2004 09:00 PM
blitz-integra
Audio / Security / Video
May 19, 2003 01:50 PM
