D16A6 head on D15B2 block?
Old May 18, 2003 | 07:39 AM
upstatecrx's Avatar
Default D16A6 head on D15B2 block?
i've got a friend that i'm trying to piece a motor together for him. he's got a 1990 DX civic and the head is shot. i have my old A6 head that i was going to put on. so just wondering if this swap will work.
Old May 18, 2003 | 07:42 AM
TomO's Avatar
Default Re: D16A6 head on D15B2 block? (upstatecrx)
IT will bolt right up, but to get the most out of the new head, do the MPFI swap.
Old May 18, 2003 | 07:51 AM
Louie B.'s Avatar
Not only will it bolt right up, the heads are Identical except for the cam and valvesprings.
Old May 18, 2003 | 08:54 AM
Hybrid Invasion's Avatar
Default Re: D16A6 head on D15B2 block? (thumpu77)
wait, an a6 head will fit on a b2 block? since when?
Old May 18, 2003 | 09:41 AM
TomO's Avatar
Default Re: D16A6 head on D15B2 block? (Hybrid Invasion)
Since they are identical except for the springs and cam, I've thrown an A6 onto B2 blocks several times.
Old May 18, 2003 | 10:47 AM
bottlefed91crx's Avatar
Default Re: D16A6 head on D15B2 block? (SonicGSR98)
Yeah they will, I did that swap onto my 1.5, bolts right up with no mods at all.
Old May 18, 2003 | 12:39 PM
Louie B.'s Avatar
Default Re: D16A6 head on D15B2 block? (bottlefed91crx)
Use a Y8 head gasket while you're at it to bring up the CR a little.
Old May 18, 2003 | 01:22 PM
upstatecrx's Avatar
thanks for the replys guys. i was 99% it would work, but just wanted to make sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">Use a Y8 head gasket while you're at it to bring up the CR a little.</TD></TR></TABLE>
good idea about the y8 gasket i'll prob do that too.
Old Jul 3, 2003 | 03:19 PM
slywfbpsi's Avatar
so, does that mean you can just buy cams and valvesprings for a a6 and put them in a b2 head?
Old Jul 3, 2003 | 05:47 PM
Louie B.'s Avatar
Default Re: D16A6 head on D15B2 block? (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">so, does that mean you can just buy cams and valvesprings for a a6 and put them in a b2 head?</TD></TR></TABLE>
yep.
Old Jul 3, 2003 | 06:58 PM
slywfbpsi's Avatar
mmmmmm...precious
Old May 18, 2005 | 03:07 PM
ninjarico's Avatar
I can't seem to get a clear answer if there is or is not a cam gear issue....anyone?
Old May 18, 2005 | 04:01 PM
vegaskurt's Avatar
Default Re: D16A6 head on D15B2 block? (ninjarico)
Cam gears are the same, but the cams are indexed differently.... So at best you will be off a little bit on timeing. Its possible to do, just not simple.
Old Mar 22, 2010 | 02:37 AM
steeltoe's Avatar
additional great info to help clarify for some
https://honda-tech.com/forums/showth...6a6+head+d15b2
hopefully it'll save someone some grief
kauai96
Apr 8, 2024 12:41 PM
justinCO
Jun 10, 2008 09:16 AM
hb_guy
Jan 16, 2006 07:31 AM
