D16Z 8000rpm 11.5:1 C/R with standart rods
Old May 18, 2003 | 05:39 AM
jt-sport's Avatar
Default D16Z 8000rpm 11.5:1 C/R with standart rods
will it be save to run d16z to almost 8000rpm , 11.5:1 C/R on standart conrod??
what the higest C/R to run on 92 octane gasoline??
what is the wildest cams for this engine?? (the spec pls)
Old May 18, 2003 | 08:11 AM
xXx Justin xXx's Avatar
Default Re: D16Z 8000rpm 11.5:1 C/R with standart rods (jt-sport)
that is alot of compression for stock rods dude.... and to go to 8k i would think you would have to have some head work done.. like better valve springs and retainers or something. but im not positive on any of this. i mean. i have a d16z6 on 10psi... so how ever much compression that makes? on stock rods...could be more.heh. i would like to know how to make it dafe to redline at 8k though
Old May 18, 2003 | 08:16 AM
eg6ajk's Avatar
yes standard rod can take 8k rpm for a while.
how high of c/r on 92 octane will depend on many things, from head design to ECU/ignition timing, fuel setting to overall design of the pistons and the combustion chamber
check http://www.crower.com they offer many race cams as well custom made cams if you want more lift or duration then you see.
Old May 18, 2003 | 08:18 AM
sappsycho's Avatar
If you're going to run that high of compression ratio, get it tuned to be on the safe side.
Old May 18, 2003 | 09:16 AM
MrJasey's Avatar
Default Re: D16Z 8000rpm 11.5:1 C/R with standart rods (SOHC Beast)
u would want to upgrade your valvetrain to run at that high RPM without breaking anything
Old May 18, 2003 | 09:21 AM
Quik Chris's Avatar
Default Re: D16Z 8000rpm 11.5:1 C/R with standart rods (MrJasey)
Why? Take that money and get a DOHC and go faster. SOHC rods are weak.
Old May 18, 2003 | 11:07 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: D16Z 8000rpm 11.5:1 C/R with standart rods (Quik Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris &raquo;</TD></TR><TR><TD CLASS="quote">Why? Take that money and get a DOHC and go faster. SOHC rods are weak. </TD></TR></TABLE>
how about shutup and move on....no one cares about your dohc engines here
Old May 18, 2003 | 12:33 PM
Rydaddy's Avatar
Default Re: D16Z 8000rpm 11.5:1 C/R with standart rods (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
how about shutup and move on....no one cares about your dohc engines here</TD></TR></TABLE>
I will be running about 11:1 compression with LS rods and a6 pistons. I wouldnt trust the d-series toothpicks past 7k rpm's.
Old May 18, 2003 | 02:20 PM
RyanEJ8's Avatar
So are the DOHC rods. That's why I bought Eagles.
RomeOWN
Apr 7, 2012 05:17 PM
snobordboy
Jan 5, 2012 06:26 AM
Fuzion
Apr 7, 2005 03:38 PM
jt-sport
May 18, 2003 10:14 AM
