My Oil Light goes on and OFf when I rev engine High it goes Off then ON please help
Old May 18, 2003 | 01:45 AM
bossman032's Avatar
Default My Oil Light goes on and OFf when I rev engine High it goes Off then ON please help
Here is my problem.
My car Oil lights keep going on and off.
When I rev my car high the Oil light goes away but when it come back to Ideal the lights come on again.
I have checked engine oil it has enough oil!!!
is their anyway I can see if the sensor is bad or maybe wiring is dead?
Please help out if you can!!
its holding back my vtec
thanks
ronald
Old May 18, 2003 | 01:47 AM
Stupid Ass's Avatar
Default Re: My Oil Light goes on and OFf when I rev engine High it goes Off then ON please help (bossman032)
Is your VTEC wired up correctly and is the solenoid working? Do you have a test light? Use that and have a buddy rev the motor and then check to see if you have conitinuity with the wiring!
Old May 18, 2003 | 06:15 AM
Hondasaurs's Avatar
My buddie just had the same problem. Oil level and everything was good. Does it bog down when you get on it? May be a sign of you oil pump going bad. We never got to troubleshoot my buddies because it shot the rod through the block shortly after the oil light stated coming on and off.
Old May 18, 2003 | 07:12 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">
Keep on revving it and the problem should show itself soon. Probably out the side of the block.
Old May 18, 2003 | 04:34 PM
bossman032's Avatar
Default Re: My Oil Light goes on and OFf when I rev engine High it goes Off then ON please help (B17A Hatch)
the car does not BOG when light comes on!!!
it drives normal but it goes on and off.
when I rev high it goes away but after it comes back to regular idel it appears again..
thanks
everyone
Old May 18, 2003 | 04:36 PM
Rob!'s Avatar
are you overdue on an oil change? its a long shot but u could try changin oil
Old May 18, 2003 | 04:42 PM
bossman032's Avatar
Default Re: My Oil Light goes on and OFf when I rev engine High it goes Off then ON please help (b16hf)
well I just did the swap like a few week ago didn't even drive it for 50miles yet.
in my std hatch.
I don't think it needs an oil changin.. I have oil I can try to change it see what happens..
Old May 18, 2003 | 05:20 PM
philly-O's Avatar
its the oilpump. thats usually what happens as they go bad (loosing pressure under higher rpm).
Old May 18, 2003 | 06:23 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Before you go replacing the pump, drop the oil pan and clean the oil pickup tube and screen. If it looks all gummed up, that would be the cause of your problem.
Old May 18, 2003 | 06:48 PM
Vince_badaz's Avatar
Same thing happened to me
15 minutes later I has a speed hole in the block
Old May 18, 2003 | 06:53 PM
dattegbol's Avatar
check the pickup as stated if thats ok i would say 80% sure its the pump , just can't make any pressure at idle. good luck
Old May 18, 2003 | 08:00 PM
bossman032's Avatar
Default Re: My Oil Light goes on and OFf when I rev engine High it goes Off then ON please help (Vince_badaz
what u mean by that?
speed hole?
the block blew up or it shot a hole through the block?
Old May 18, 2003 | 09:48 PM
bossman032's Avatar
Where do I check before I replace the Oil PUMP the **** I squared?
Thanks
ron
Old May 19, 2003 | 12:16 PM
bossman032's Avatar
Will a dented oil pan also cause this problem?
thanks
Old May 19, 2003 | 12:45 PM
Blaze45's Avatar
Brrraaaap!
possibly yes, could mess up your pickup.
Blaze
Old May 19, 2003 | 01:09 PM
CimorelliCRX's Avatar
If the oil pan is dented enough it can, but check your connecter on the back of the block for the oil sending unit. Make sure the connection is good.
Old May 19, 2003 | 02:45 PM
bossman032's Avatar
Yes I think that is the case because when I rev high it gets oil.
I talked to Old man who fixes car he explained to me how it works he said working with car that long Honda doesn't **** up Oil Pumps. I told me about the dent on the Oil Pan he said that might be the problem also.
told me get a wood and hit the oil pan out..
Old May 20, 2003 | 06:30 PM
bossman032's Avatar
Hello everyone,
thanks for the input I fixed the problem today thanks again for the people who posted!~~~
hope yo post on my next topic
problem was the PickUp Coil was bent I fixed the Oil Pan dent and the Pickup and everything works.
thanks yo..
Sfedai0
Jun 21, 2007 02:30 PM
Cashflo
Sep 26, 2006 01:47 PM
DC_RaceR
Feb 23, 2006 02:00 PM
Foxcow
10
Dec 16, 2004 08:56 PM
lilxvtecxpwr
Sep 4, 2003 10:51 PM
