Okay, I revved past rev limiter....
Old May 17, 2003 | 11:39 PM
Racer X's Avatar
Default Okay, I revved past rev limiter....
... to about 8500 and I am quite paranoid now. I hope I didn't bend any valves. The car seems to be idling okay. Is there anything I should look for, or did I get lucky and not cause any damage? It's a stock 2000 GS-R by the way. TIA.
P.S. I was being careless (which usually I'm not) so please let me know if I should get it checked or not or what to look for to tell if I damaged it.
Old May 17, 2003 | 11:45 PM
NUTWEAVE's Avatar
Default Re: Okay, I revved past rev limiter.... (Racer X)
SHAME ON YOU!
j/k
i would have to say.....if it doesn't feel broke, then don't worry about fixing it.
Old May 17, 2003 | 11:49 PM
Heisdan's Avatar
Racer X do you play counterstrike i think I saw you on one time
Old May 17, 2003 | 11:52 PM
Racer X's Avatar
Default Re: (Heisdan)
Wasn't me sorry, although I've played it before, I haven't played onlinee.
Old May 17, 2003 | 11:54 PM
Racer X's Avatar
Default Re: Okay, I revved past rev limiter.... (NUTWEAVE)
yeah that's what I figured but still, it's my baby ya know, so I have to worry! Haha, anyways, I'll just keep an eye on it. I just wanted some reassurance to know I didn't screw up. I'd hate to have to replace the valvetrain, darn, new high performance valvetrain....
Old May 18, 2003 | 12:06 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
revving in neutral?
or misshifting?
you can't go past the rev limiter unless you're a) misshifting or b) running with a removed redline
Old May 18, 2003 | 12:30 AM
AllmotorJunkie's Avatar
Default Re: Okay, I revved past rev limiter.... (dLo GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">revving in neutral?
or misshifting?
you can't go past the rev limiter unless you're a) misshifting or b) running with a removed redline</TD></TR></TABLE>
Good point!
Old May 18, 2003 | 08:51 AM
neo1z's Avatar
Default Re: Okay, I revved past rev limiter.... (AllmotorJunkie)
I dont beleive one stint to 8500 is going to bend any valves.
Old May 18, 2003 | 08:56 AM
ebelp's Avatar
Default Re: Okay, I revved past rev limiter.... (neo1z)
You should be fine. Just don't do it ever again!
Old May 18, 2003 | 09:06 AM
VTEC-DA's Avatar
Default Re: Okay, I revved past rev limiter.... (ebelp)
And as long as it was only to 8500, that isnt even really that high. Your car is fine.
Old May 18, 2003 | 11:49 AM
Audio28's Avatar
Default Re: Okay, I revved past rev limiter.... (VTEC-DA)
your fine, if nothing happened right after you did it.
Old May 18, 2003 | 12:11 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Okay, I revved past rev limiter.... (Audio28)
i dont think anything is wrong...i did that once in my car and it is fine
Old May 18, 2003 | 12:30 PM
DR3AM's Avatar
If you're that paranoid, run a compression test and find out for sure.
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
Dooley
53
Jan 25, 2005 03:58 PM
JDM00SI
Sep 17, 2004 01:14 PM
V-SPEC 1
Jan 1, 2004 06:47 PM
JDM_ITR
Jul 10, 2002 04:24 PM
