My CEL stays On what is the Problem Fixed Code 9!!
Old May 17, 2003 | 08:39 PM
bossman032's Avatar
Default My CEL stays On what is the Problem Fixed Code 9!!
Here is what I have!!
SIR II motor in a Civic Hatch STD.
I had Code 4, and 9. I fixed it today by running the wires direct from the ECU to the Engine harness.
I accidentally cut the Blue/Green wire for the TDC but I crunched them together and put tape on it and the TDC went away also.
But now I fixed all the codes and the Check engine light stays on wtf?
This **** gay.
Please help if you know what’s wrong.
FYI: if I unplug the CKP wires it gives Code 4 or any sensor wires but when everything is plugged in the CEL stays ON!!!
Old May 17, 2003 | 09:39 PM
G2turbo_terror's Avatar
Default Re: My CEL stays On what is the Problem Fixed Code 9!! (bossman032)
have you re-set the ecu? Pull the 15 watt fuse in the fuse compartment on the passenger shock tower, its labled ecu or computer or something...But I'm kinda in the same boat. I finished my mpfi swap today and I had a code 7, map sensor, fixed it and the cel went off but the code is still in the computer...
Old May 17, 2003 | 10:00 PM
bossman032's Avatar
Default Re: My CEL stays On what is the Problem Fixed Code 9!! (G2turbo_terror)
yes I tried to reset the ECU.
by sticking the Pin the Blue ****!!
I also tried taking out the fuse for 15seconds didn't work.
before this is how i reset the ECU just take out the - on the battery and it resets.
what can be the problem please help Me and Turbo out!!!
Old May 17, 2003 | 10:33 PM
CimorelliCRX's Avatar
the best way I reset my ecu is by unplugging it, I never had any luck by pulling the fuse... Just unplug the ecu and it should be good. Code 7 is TPS. 3 and 5 are map... FYI
Old May 17, 2003 | 10:50 PM
Malgerus's Avatar
Default Re: My CEL stays On what is the Problem Fixed Code 9!! (CimorelliCRX)
Unplug the hazard fuse, and ECU fuse and let it sit for a few minutes.
Old May 17, 2003 | 11:05 PM
bossman032's Avatar
Default Re: My CEL stays On what is the Problem Fixed Code 9!! (Mr. S)
I also tried to reset hell times nothing has happened it stays on on the Cluster because I am running OBD1 but when I unplugg any sencor like ckp or map or whatever it gives the code of what ever I unplug like If Unplugg the Oil Pressure on the Vtec senolid it gives code 22. two long blinks and 2 short. but when everything is plugged in that CEL stays on forever!!!
Old May 18, 2003 | 08:55 PM
bossman032's Avatar
never mind I just found out from the GUY who made my harness that normal when everything is kool the light will stay on forever and I just need to turn off the switch to make it go away.
new_climber
Sep 17, 2009 08:26 AM
jetblack
May 16, 2006 06:20 PM
HATCHFIEN
Nov 1, 2004 10:00 PM
GeorgeY
Jun 29, 2003 08:59 AM
ArchAngel Sabastian
Oct 23, 2001 07:39 PM
