loosening tie-rod lock nut?
Old May 17, 2003 | 05:46 PM
216.226.142.95:27016's Avatar
Default loosening tie-rod lock nut?
any tips, im having trouble loosening mine.
Old May 17, 2003 | 05:53 PM
TerribleOne's Avatar
Default Re: loosening tie-rod lock nut? (216.226.142.95:27016)
you've used the liquid wrench ands stuff on it, let it marinate in that, or if you're haveing a LOT of trouble still after that then take a torch to it and heat it up, always works for me...
Old May 17, 2003 | 06:35 PM
Default Re: loosening tie-rod lock nut? (TerribleOne)
turn counterclock wise as usual? im having a brain faurt weather it spins the same direction as if im facing or im behind it.
Old May 17, 2003 | 10:43 PM
IN VTEC's Avatar
Look at it from the POV of the tie rod end. You would turn it CW to thread it on, so turn it CCW to thread it off (and the locknut the opposite way).
markrages
Suspension & Brakes
May 5, 2014 10:11 AM
B_Swapped93
Dec 6, 2013 06:30 PM
Peeb
Honda Civic (2001 - 2005)
May 31, 2012 03:47 PM
zccr-xsi
Suspension & Brakes
10
Sep 30, 2005 03:57 PM
Matt B
Apr 23, 2004 12:20 AM
