Crank Pulley Removal
Old Jul 10, 2001 | 12:54 PM
13secLSVTEC's Avatar
New User
Default Crank Pulley Removal
I've got the block out of car(B18B)...pistons & rods out...can't get the crank pulley off...I've tried WD-40, impact wrench, breaker bar w/ pipe....can't get the damn thing loose...no I don't have a strap wrenck like Haynes says to use...please help...WHAT WORKS???
Old Jul 10, 2001 | 01:05 PM
keithv's Avatar
Default Re: Crank Pulley Removal (13secLSVTEC)
There are a few ways to go about this...
A nice 4 FOOT (yes FOOT) break bar and have some STAND on the brakes.
OR
Get a set of channel locks from Home Depot (I think they are called "Big Azz"...no joke) and an impact gun.
I know this has been discussed many, many times on the Hybrid board (http://www.hybridforum.com/postlist.php?Cat=&Board=Tech).
HTH.
EDIT: I can't spell...
[Modified by breaka_1_9, 5:06 PM 7/10/2001]
Old Jul 10, 2001 | 01:12 PM
raene's Avatar
Default Re: Crank Pulley Removal (breaka_1_9)
First off, his block's out of the car... standing on the brakes would accomplish nothing... heheheh...
Anyway, what I did is wedge a bolt between the teeth of the flywheel and a transmission bolt, then use a 3-ft breaker bar. I'll see if I have a pic.
Old Jul 10, 2001 | 02:04 PM
New User
Yea, the brakes wouldn't help too much...lol
That looks like a good idea with the flywheel...have to try it...
anyone else have any ideas?
Old Jul 10, 2001 | 02:23 PM
raene's Avatar
It's not my idea, that's from the Haynes manual... I don't think there IS an easier way to remove the bolt, unless you have air tools .
Old Jul 10, 2001 | 03:03 PM
New User
I do have air tools....Wal Mart's finest...lol
Needless to say they are worthless at breaking loose stuck bolts...
Old Jul 10, 2001 | 05:16 PM
keithv's Avatar
You'll need at least 125 lbs of pressure in the air tool to get the crank pulley off.
I've heard of 500 lb to 1100 lb tools not getting crank pulleys off...
Go the old fashion way...earn it! Get a ncie big bar, slip it of your rachet and put some even pressure on it.
Old Jul 10, 2001 | 05:30 PM
raene's Avatar
I wouldn't use a ratchet, I'd use a breaker bar. Unless you have a good ratchet you'll probably break it .
Old Jul 10, 2001 | 05:35 PM
keithv's Avatar
Default Re: Crank Pulley Removal (raeneshadow)
I meant to say breaker bar, unless you have a craftsmna rachet and want a new one.
Old Jul 10, 2001 | 06:46 PM
raene's Avatar
LOL!
Old Jul 10, 2001 | 06:59 PM
New User
Already broke my Crafstman on it...lol...forgot I had a breaker bar....
My problem is getting the block to not move when I'm trying to get it off....lesson learned...TAKE THE CRANK PULLY OFF WHILE THE BLOCK IS IN THE CAR KIDS....
Old Jul 10, 2001 | 07:16 PM
raene's Avatar
LOL... I had my mom hold the block in place while I yanked on the pulley bolt .
Old Jul 10, 2001 | 07:22 PM
KayOs's Avatar
Moroso makes a crank pulley removal tool for Honda 1.6L and Acura 1.8L. it allows you to hold the crank pulley in place while trying to work the bold loose. made my job a lot easier. Summit Racing carries this tool for around $70.
Old Jul 10, 2001 | 08:58 PM
New User
Sounds nice, but I think about $30 worth of cement blocks would work too..lol
Old Jul 10, 2001 | 09:04 PM
quikrpm'z's Avatar
_______
I had to get my mom and dad to hold down the engine, to remove the head bolts.
Old Jul 10, 2001 | 10:24 PM
sparkz's Avatar
What I did was just stick a screwdriver (craftsmen preffered) thru o ne of the holes in the flywheel and had it lodged against the tranny. Then just use a breaker bar and it should come off
Old Jul 10, 2001 | 10:54 PM
New User
I've tried that too....anyone got a fat girlfriend I can borrow to sit on the block while I get it out???
methos713
May 24, 2007 05:52 PM
f150harleytruck7
10
Dec 20, 2005 08:09 AM
Draggin99Si
59
Feb 20, 2005 11:59 AM
TrueZen
Feb 27, 2004 07:42 AM
yuckymucky
21
Mar 30, 2003 07:04 PM
