First upgrade on integra
Whats the budget? How many miles on that motor? I mean if the motor is on its last leg id consider getting another one prior to anything else. If you want to keep that motor - then I would do suspension first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE »</TD></TR><TR><TD CLASS="quote">A good tune up should always be your first mod.
if it's a used car, I'd say a major tune up. Just to make sure the car will be stable for the next couple thousand miles before you started to mod it. when u have the money or already have, then suspension/tires. get control of ur car before u go fast
besides, it's the tires and the suspension that holds ur car not the turbo nor the kragen intake pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA gs-R 05 C »</TD></TR><TR><TD CLASS="quote">suspension.
I agree
</TD></TR></TABLE>I agree
I'll probably get the tune up first, but this is a new car i'm getting within a month and a half, but i'll probably get it checked out, then get suspension and then decide if I want to swap the engine or not. But if I do, is a JDM b16a good for a turbo?? cuz I know it just fits in the RS integra..but would ya'll put a turbo on it??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradester »</TD></TR><TR><TD CLASS="quote">Would ya'll put a turbo on the jfm b16a tho? or just go all motor on that engine</TD></TR></TABLE>
They'll both work good. It all depends on personally preference.
If you have the money for a B16 swap and a turbo setup, you may want to consider dropping a bigger motor in there (i.e. B18xx, B20). That way you'll have alot of room to work with later on.
