aem big rotor vs integra brake upgrade
Old May 17, 2003 | 09:42 AM
DOHCTOR's Avatar
Default aem big rotor vs integra brake upgrade
has anyone experienced with both of these front brake set ups, intergra master, caliper and front rotor system upgrade (9.0 to 10.3) vs the aem big rotors...does the larger caliper piston and larger brake pads on the smaller rotor size (integra system) have the same affect as the smaller caliper and pad size (stock civic) and the larger rotor size (aem)???
Old May 17, 2003 | 11:28 AM
built562's Avatar
Default Re: aem big rotor vs integra brake upgrade (DOHCTOR)
i have done this, i had a 95 dx and then put gsr brakes all around and then later i put big brakes on the front. but i dont really understand your question but im sure i can help.
Old May 17, 2003 | 11:40 AM
DOHCTOR's Avatar
the AEM kit is just bigger rotors using the stock calipers on a si hatchback. the smaller stock calipers has less clamping force then the larger intergra calipers...
the integra setup will have more clamping force on the rotor and more brake pad surface area than the smaller civic brakes...
Old May 17, 2003 | 10:21 PM
'92SiHatch's Avatar
I heard the aem big brakes tend to warp after awhile, afriend has them front and back and the steering wheel is real shaky during hard braking.. go with integra brakes
sunnydeez
Apr 14, 2006 05:28 PM
mglude
Jan 21, 2003 06:53 AM
shawnhayes
47
Jan 9, 2003 01:42 PM
Altered_Ego
11
May 7, 2002 01:58 PM
sicilian2k1
Nov 15, 2001 03:18 PM
