Helper springs on HAs?
Old May 17, 2003 | 09:19 AM
fowler!'s Avatar
Default Helper springs on HAs?
I talked to someone yesterday who said that the helper springs on his HAs were unnecessary. I used to have HAs before and I decided to keep them (the helper springs) in, as I saw no advantage to taking them out.
Am I missing something? What would be a good reason to remove the helper springs?
Old May 17, 2003 | 09:36 AM
bus stop's Avatar
Default Re: Helper springs on HAs? (fowler)
I don't believe there's any advantage to take them out too.....Btw, I've helper spring in rear but not in front and I don't see/feel any different the way they perfrom.
Old May 17, 2003 | 04:22 PM
jdmjunky's Avatar
Default Re: Helper springs on HAs? (WhosITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhosITR &raquo;</TD></TR><TR><TD CLASS="quote">I don't believe there's any advantage to take them out too.....Btw, I've helper spring in rear but not in front and I don't see/feel any different the way they perfrom.</TD></TR></TABLE>
same setup i have since i wanted my car lower than the ideal 1.75 drop tein recommends...however, either way it matters not that much. the helper springs are required in japan because the suspension setups cannot have spring rattle. as it is known, that does not apply here in the states.
rathead81
Jun 19, 2006 04:39 PM
b18c inside
Suspension & Brakes
10
Mar 20, 2006 10:14 PM
davidnyc
17
Sep 13, 2004 12:46 PM
2 point 0
30
Apr 10, 2004 08:52 PM
Sam268
Feb 26, 2004 11:38 AM
