How to mount DSM BOV and SMIC to greddy SOHC kit?
Old May 17, 2003 | 07:15 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default How to mount DSM BOV and SMIC to greddy SOHC kit?
For the greddy SOHC kit, how do I mount a DSM BOV onto the piping? do I need to buy the flange and gasket from Road Race Engineering and have it welded on, or do I need a custom flange made? Also, do I need more piping to add a DSM SMIC onto the greddy non-ICed kit? Approx. how much?
Old May 17, 2003 | 09:08 AM
Pritos's Avatar
New User
Default Re: How to mount DSM BOV and SMIC to greddy SOHC kit? (fnananon)
easiest way is to get one from Road Race then have it welded on to your stock piping.
Or, if you have a dremel and a piece of sheet metal then cut your own. Cut the hole in your charge piping yourself then have a muffler shop weld it on.
cheers!
Old May 18, 2003 | 07:15 AM
bump
Old May 18, 2003 | 09:18 AM
Pengo's Avatar
for the bov if u have the dsm bov with the small section of stock pipe u can have the stock flage chopped off and any good welder and attach it to ur charge pipe. the other alternative of course is to get the flange from RRE.
as for the sidemount, if u play around with it for awhile, u'll see how it'll fit to the pipe off the the turbo and up through the hole where the stock resonator used to be. i had to cut off a small curve off of the lower piping and it fits up nicely. i even got a metal bracket and made it fit so that it actually attaches the smic to the body of the car so that it takes some weight off of the charge piping.
here are some pics. its a del sol but u get the idea:
heres the ic on the right front of the car. it doesnt touch the tire at all, even at full turn.
not the best angle but u can barely see it from the front. if u have the stock fenderliner then people wont even be able to see it from the back
Old May 18, 2003 | 01:31 PM
Sinner's Avatar
nice spot I have my mounted under my hood. I was thinking of spray CO2 on it when I wanted some help.
Nick
Old May 18, 2003 | 06:57 PM
BuddyLee's Avatar
Default Re: (Sinner)
spraying carbon dioxide??
Old May 18, 2003 | 07:20 PM
Accord94DX's Avatar
Default Re: (BuddyLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddyLee &raquo;</TD></TR><TR><TD CLASS="quote">spraying carbon dioxide??</TD></TR></TABLE>
yeah. Super cheap and cold as ****.
Old Jul 3, 2003 | 11:05 AM
Default Re: (Accord94DX)
bump
Old Jul 3, 2003 | 11:57 AM
mamaboy's Avatar
wait i'm sure the intercooler piping kit from greddy is aluminum.....your going to have to make the upper piping section out of mild steel for you to be able to weld the flange and an extension together....
ih8danoles
May 14, 2004 05:34 PM
Pfieff
Jul 12, 2003 10:16 AM
boostincoupe
Jun 29, 2003 06:28 PM
skierGT
May 10, 2003 08:40 PM
BigDaddyRich
Aug 26, 2002 09:06 PM
