major rust, need help! Pictures*
Old May 16, 2003 | 09:45 PM
eur0's Avatar
Default major rust, need help! Pictures*
is this beyond repair? i dunno if its even worth messin with? Its got a hole in the fender liner aswell so waters gettin inside the body, hmmm
Old May 16, 2003 | 09:48 PM
RCautoworks's Avatar
Get a hole new panal and weld it in, are your headlights red ?
Old May 16, 2003 | 09:53 PM
eur0's Avatar
Default Re: (90blackcrx)
just a rear fender piece? cause as you can see the inside of the fender (the lining) is also rusting away so I was just wondering? maybe some rust inhibitor?
Old May 16, 2003 | 09:56 PM
Default Re: (tbk49)
See how rusted it is from the inside, and see if it can be saved. Body shops can work some miracles as long as the frame ain't bent.
Old May 16, 2003 | 11:04 PM
TheHatchHog's Avatar
it is hard to find crx rear corner pannels to weld in , and even if you do it will cost a fortune, and you will still have to fill and smooth over welds with fiberglass or bondo, with glazing puddy. I had a 1970 ford torino GT, there was a small portion of the rear corner rusted out , not nearly as bad as that though. what we did was buy the flat sheet metal, then bend it as best as we could, and weld in place.This leaves a good solid foundation for the body m guys to work with. I then brought the car to a body shop that is owned buy a good family friend. he did the resaping and fiberglass work, looked brand new in the end, you just have to find some one that will do it for a good price but that does good work, cause it aint a easy job. try autobodyparts.com they are one of the biggest oem body parts places around online. i know that they carry hoods, front fenders brand new left overs from the factory , but rear corner patch panels may be hard to find ,,,good luck!
Old May 16, 2003 | 11:26 PM
Mr.SpiLLz's Avatar
well... yah i had the same kind of problem, but mine was on the drivers side, i also had wholes in my fender wall and rust in my door sill, for the part(rear panel of a junk car) and the body shop work i payed around a grand.... I kind of wish i would have just got a different car or a shell, but now that i have it done its done, so im just going to stick to this car untill its all clean, it may cost me alot but at the end ill be happy. If you really want to keep your car and have the money to fix it a good body shop can do it, but its going to be hard to find a body shop that does rust repair.
Old May 17, 2003 | 12:01 AM
Default Re: (MrSpiLLz)
Well honda charged around 400 for an outer an inner real panel, you would have better luck going to the junkyard and cutting pieces of the body there.
Old May 17, 2003 | 12:20 AM
Mr.SpiLLz's Avatar
My junk yard rear quarter was like 200... Most of the money is the body work cuz they have to cut and fit and weld and putty and paint....
Old May 17, 2003 | 12:42 AM
Ham'ed Hatch
Guest
Posts: n/a
good lord! gotta love sunny AZ! that ****'ll NEVER happens to an original AZ car...
Old May 17, 2003 | 01:54 AM
HF2ZC's Avatar
Default Re: major rust, need help! Pictures* (tbk49)
Well, that's as bad as i've ever seen. If you are looking at this car for purchase, consider it as a parts car, if at all. If you already have it, I would definitely look into getting another car, as the repairs to this CRX are going to be just as expensive (if not more so) than buying a whole new EF. That CRX is going to need not just the rear quarters and fenderwells, but probably also new sunroof drainage tubes, and a new rear bumper. In addition, you may find horrors upon removing the rear bumper, they tend to rust badly behind it. If you live in a climate that salts the roads in the winter (and I assume you do), consider an HF or DX model CRX, as they do not have the sunroof drainage tube rust out problem.
Old May 18, 2003 | 11:04 AM
88crx Osaka's Avatar
O man that is bad just like my crx. If you know how to play with fiberglass and bondo and putty you can make it look better but never make it like new. Its not worth to pay someone to do it. Just fix it little bit and look for better looking CRX shell and start from there. I will post pics next week how my CRX is doing.
Old May 18, 2003 | 03:38 PM
Ef Whore's Avatar
Default Re: major rust, need help! Pictures* (88CRX)
Goddamn my friend those 1/4's are fucked. That is bad rust. If you love the car then weld a new 1/4 in, but it makes me wonder how rusty the underside is. Thank god my part in Jersey is rust free.
Old May 18, 2003 | 06:28 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Oh man, that's bad.
You need one of these. Too bad you live so far from me, I cannot ship this thing.
Old May 18, 2003 | 09:34 PM
Default Re: major rust, need help! Pictures* (Spaceballs the lunch box)
Just woundering, Spaceballs the lunch box how much did you pay for that thing and where did you get it ?
Old May 18, 2003 | 10:02 PM
Mr.SpiLLz's Avatar
Default Re: major rust, need help! Pictures* (90blackcrx)
If anyone can help me with my rust problem can you go check out my thread at https://honda-tech.com/zerothread?id=509636 Its on the crx, but i thought it should go in appearance but now no one is answering.. So maybe some of you guys know =/
Old May 18, 2003 | 10:25 PM
bossman032's Avatar
Default Re: major rust, need help! Pictures* (MrSpiLLz)
I paid 39 bucks for this!! Well me and My helper cut it!!!
too bad u don't live close by other wise I could have hooked you up maybe 50-120. for the entire ****!!!
then
100% factor well not 100% but 95%
Old May 18, 2003 | 11:16 PM
eur0's Avatar
Default Re: major rust, need help! Pictures* (bossman032)
heres an update! haha
its pretty damn bad, i think im gonna make a fiberglass mold from my hatchie and stick it in there...the dmg is too much to even consider welding
HELL HELL HELL
A little work in progress...
Old May 18, 2003 | 11:23 PM
Mr.SpiLLz's Avatar
a fiberglass mold of the wheel well? Or what, if the wheel well what you gonna do like cut out the rusted metal then screw in the fiberglass mold? If so i'de be interested in one ... If the mold is of the wheel well how do you know they are the same, why dont you just mold the other side of the crx?
Old May 18, 2003 | 11:54 PM
Damn someone could make lot of money if the made fiberglass 1/4 panels for CRX
Old May 19, 2003 | 12:13 AM
philly-O's Avatar
the easy and ghetto way would fill the area with foam and fiberglass over it when it has been shaped. that would only be a temporary fix though since you would only be fixing the problem instead of eliminating the problem.
Old May 19, 2003 | 01:42 AM
Mr.SpiLLz's Avatar
yah but i never worked with fiberglass, does fiber glass stick to metal or what? I'de be willing to give it a try, I just want to be sure it would work.
Old May 19, 2003 | 06:34 AM
89civicdx's Avatar
contact this guy (hes in toronto)
cashcrx@hotmail.com he can either fix that if you bring it down or can send you the rear section
his name is Nick
Old May 19, 2003 | 11:54 AM
brent_G's Avatar
Default Re: major rust, need help! Pictures* (89civicdx)
hey thats stage one weigh reduction and you dindt have to pay for it! id prolly just give up on trying to make it nice...be more money then its worth to fix it right. And it will come back if you fiberglass it...always does...usually lasts 2 years tops with a good job. turn it into your race car and invest money in something new
Old May 19, 2003 | 12:52 PM
Hcivic88's Avatar
Default Re: major rust, need help! Pictures* (screamincivik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamincivik &raquo;</TD></TR><TR><TD CLASS="quote"> And it will come back if you fiberglass it...always does...usually lasts 2 years tops with a good job. turn it into your race car and invest money in something new</TD></TR></TABLE>
2 years ago, before i knew anything about body work, i just sanded it down a bit and packed mine with bondo, lol, it wasnt even fiberglass. It lasted atleast 2 years and it was just starting to fall out now, i think the fiberglass will last longer than 2 years if its done right.
Old May 19, 2003 | 07:02 PM
eur0's Avatar
Default Re: major rust, need help! Pictures* (Hcivic88)
i started fiberglassing the roof today haha, i realize the car isnt worth throwing money into but it will give me some practise on bodywork!
