Oil pressure sending unit question
Old May 16, 2003 | 08:00 PM
RCautoworks's Avatar
Default Oil pressure sending unit question
I was told I would need a 1/8 bspt male to 1/8 npt female to hook my electric oil gauge up, I was told the new sending unit does not have the right threads to use on my block. Can anyone else confirm this, because I am having a hard time finding this fitting. Any help ?
Old May 16, 2003 | 08:19 PM
Default Re: Oil pressure sending unit question (90blackcrx)
Well if I do need it, the autozone website says they should have it at my local store. So the guy working there lied to me and said they only had the ones behind the counter.
Old May 16, 2003 | 08:39 PM
jspek29's Avatar
yup u have to use bspt, its kinda like the standard and metric thing, bspt is british standard pipe thread, and npt is national pipe thread.
Old May 16, 2003 | 08:55 PM
MADEINIRAQ's Avatar
Default Re: Oil pressure sending unit question (jspek29)
you do need it ... i got mine from the V8 dressup isle(at autozone).. i think it was in a pack with an assortment of brass adapter fittings made by sunpro...
Old May 16, 2003 | 09:10 PM
Default Re: Oil pressure sending unit question (madeiniraq)
Did it come with a clear hose to ? Thats the one I saw on there website. The guy at the store looked threw a bunch of them behind the counter that were in a big box and said he did not have anything and I asked him if he any in the ile and he said no. But then he said a shipment was coming in, so I'm gonna go back to that store and see if they have it, if not I'm gonna have to run to the other autozone. Thanks guys.
Old May 16, 2003 | 09:18 PM
Is this the thing you bought ?
Old May 16, 2003 | 10:07 PM
MADEINIRAQ's Avatar
no, it only had bushings.. (the third from the left)
Old May 16, 2003 | 10:31 PM
Ok, thanks
Old May 17, 2003 | 10:02 AM
Is the size 1/8-28 bsp to 1/8 npt ? That should work right ?
Old May 17, 2003 | 11:50 AM
Well the thing looks like it will screw into the block, but it don't screw into my oil pressure sender all the way, it only goes about 2 full turns. I tryed threading my old stock sending unit into the brass adapter and it goes right on, all the way to. Now what ? Did I get the wrong fitting ? Or is it not suppose to fit on all the way ? Just for the hell of it, I tryed the fitting they gave me with the sender, and it does the same thing as the other ones do. It won't thread all the way on. Is this normal ? If it don't thread all the way, but its still tight and I use thread sealant, do you guys think I'll be ok ?
Modified by 90blackcrx at 3:12 PM 5/17/2003
Old May 17, 2003 | 01:48 PM
Alittle update, I went back and exchanged the ones with the same ones, because it seems like all the packages have been open. Plus I bought the t fitting. Well the sending unit still will not plug into the adapter piece. But the t fitting does. But then the one piece of the t fitting will not go into the block. So I'm gonna have to use some of the other adapters plug the t fitting. I can't beleive the regular adapter won't fit.
Old May 17, 2003 | 09:29 PM
I figured it out, well basically the T fitting piece worked plus some other adapters. I'm gonna keep a close eye on it and make sure its good to go becase I know some people had trouble with it coming loose, but I also know some people that never had a problem with it getting loose. Thanks for the help.
Old May 18, 2003 | 12:04 AM
SiR Kid's Avatar
New User
BPST is a flared thread. The fact that it only went in two threads means you were putting a standard or AN fitting into a BPST adapter or vice versa.
FYI.
you were doing this:
\_/ this was trying to thread into
|_| this, basically. Make sense?
Old May 18, 2003 | 06:46 AM
keithv's Avatar
Default Re: Oil pressure sending unit question (SiR Kid)
90blackcrx...check your IMs. i have some info in there for you.
Old May 18, 2003 | 07:29 AM
EFsleeper's Avatar
Default Re: Oil pressure sending unit question (keithv)
I just picked up my fitting for my sender from Summit. They had them availible from Autometer. The fitting was like 9 bucks shipped. Im still have trouble finding the the reverse fitting to keep my factory pressure switch in the Tee. Can anyone help me out on that one? Im talking about the 1/8" NPT male to 1/8"BSPT female. Thanks.
Old May 18, 2003 | 10:09 AM
jasonb's Avatar
found this diagram on this forum, may help you find the pieces you need.
Old May 18, 2003 | 07:01 PM
EFsleeper's Avatar
Default Re: Oil pressure sending unit question (jasonb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasonb &raquo;</TD></TR><TR><TD CLASS="quote">found this diagram on this forum, may help you find the pieces you need.
Thanks man, But I know how to hook it all up and what pieces I need. Like I said I have EVERYTHING I need but piece "B" that is posted in that diagram. Where did everyone else get theirs from? Ive gone to plumbers supply stores, home depot, lowes everywhere, and when I ask for British standard pipe thread they look at my like Im from the Taliban or something.
Old May 18, 2003 | 08:39 PM
I tryed autozone, I actually picked up 2 of them but the gauge would not screw into it.
Old May 19, 2003 | 09:13 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (90blackcrx)
My pics, on my B16A will be up late tonight.. i have to download them, and throw them up on my FTP.. they will be up later on tonight.
its very true that mounting it they way i did, and a solid connection to the block could vibrate, and break off.. i've never seen it.. but its possible.. but looking threw the post, and that pic above, the steal braided line, mounted to the firewall for flex.. is the ultimate way, problem free 100%.. but quite expencive.. send me 5 bucks, and i'll send you all the hardware you'll need.. a male to 2 female 1/8 NTP "T" fitting, and you'll be in bussiness.
Old May 19, 2003 | 11:21 PM
matt j's Avatar
Default Re: (Built B16A)
not to jack your thread or anything but is the oil pressure sending unit in different spots from the d-series motors to the b-series motors, when i tried installing mine the sending unit was on the top side of the oil filter and i couldnt put the sending unit in because it hit the filter, any ideas/suggestions?
TIA
Old May 19, 2003 | 11:24 PM
Built B16A's Avatar
Default Re: (mattED6)
yeah.. matt.. put your "T" in, then put your sending unit on.. the T isn't that big.. or if anything... take the filter off, put the sending unit on, and then put the filter back on.. (hopefully a new one)
Old May 19, 2003 | 11:25 PM
jasonb's Avatar
same spot...if you try to install the sending unit directly onto the block, you'll need a different filter. Someone posted that you can use a HAMP oil filter. I guess they are narrower than the OEM filter size.
Old May 19, 2003 | 11:27 PM
matt j's Avatar
Default Re: (jasonb)
ok, ya i am going to move the sending unit to the firewall, just because i dont want to run anything other than a honda oil filter
Old May 19, 2003 | 11:28 PM
Built B16A's Avatar
in a few mins.. i'll post up pics of mine.. you can use whatever oil filters you want.. watch.. a few more mins.
Old May 19, 2003 | 11:30 PM
jasonb's Avatar
ok, thanks for confirming that. I didnt think you had to use a different filter is you Tee'd off the block.... &lt;-------awaiting pics.....
