maintenance on b16, now wont run...
Been having a few problems lately..... here's a brief rundown.
Car is running good, with code 7 and 22..Install knock sensor, and calibrate TPS. Change oil and install new plugs.
Car gets a weird hesistation (hiccup) under 5k rpm. I put on a new cap.
Then i get a code 22.
So i put in the 2 vtec solenoid gaskets last night, cleaned it up a lil with carb cleaner, bought new NGK wires, put them on. NOw the car wont even run, it starts up barely, and i giving it gas i can barely get it to keep going. I double checked the plug wire order, now it seems the code 22 popped back up, after resetting the ecu.
What the hell is wrong????
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
i wouldnt recomend carb cleaner on the vtec sylinoid, brake parts cleaner or brake fluid, yea your dizzy might be going out or maybe the rotor inside my friends rotor went out and it would start up and then die or sometimes start up drive for like a few mins then die when we were like 20 mins from his house and we had to push it like 3 miles to an autozone haha. that was a crappy day.
Janky2Slow
May 26, 2007 09:18 PM
