where do i get pins for ecu plug?
Old May 16, 2003 | 04:03 PM
xXx Justin xXx's Avatar
Default where do i get pins for ecu plug?
hey, i am tring to add two wires to my ecu plugs in my 94 cx. one at a4 (big pin) and one at d6 (small pin) . well... no stock wire there to just connect it to... where do i get the pins that clip in there so i can wire my vtec? thanks
Old May 16, 2003 | 04:32 PM
lowkeyciv's Avatar
Default Re: where do i get pins for ecu plug? (SOHC Beast)
go to the junk yard with a pair of dykes and cut them out of a ex, just cut the whole ecu harness so you have more pins for later on
Old May 16, 2003 | 04:36 PM
Default Re: where do i get pins for ecu plug? (lowkeyciv)
ummm.... no . no money or time to go to a junk yard. i have a junk crx? you think if i can figure out how to get those pins out i might be able to use those? tap into the wires coming off of them. and how do i get them out of the lcip so i dont mess em up. thanks
Old May 16, 2003 | 07:26 PM
anybody else have any ideas? what does everybody else do when they have to add wires for vtec and such?
Old May 17, 2003 | 09:16 AM
Old May 17, 2003 | 10:20 AM
TommyV's Avatar
Its wicked easy to get the pins OUT OF and IN TO honda plugs.
Look at the harness, with a small flat head screw driver, pry up the little.. "flap" you will see what I'm talking about. It has to be "unhooked" before you can remove any pins.
Get a pair of solid needle nose plyers.
Grip the pin you are trying to remove very carefully and as straightly as possible.
PULL - ALOT. Pin will come out undamaged. (Vice helps alot to put the harness in)
Installation is easy, again just unhook the "Flap" on your harness, and insert pin by hand, then just push it in with the needlenose.
Close flap. You are done. Congrats you have added a Pin to ECU harness.
Good luck
Old May 17, 2003 | 10:24 AM
redegg's Avatar
Default Re: where do i get pins for ecu plug? (TommyV)
why dont you try honda, im sure it couldnt cost too much.
Old May 17, 2003 | 11:27 AM
Default Re: where do i get pins for ecu plug? (redegg)
honda is closed.... engine has to be running by tomorrow afternoon. but thanks for the info on getting them out. i just tried to use one that i took out of my crx ecu clips.... they are too big. so i guess that idea is out? anybody else have an idea? are there any wires in my stock 94 cx ecu harness that wont be used or serve a purpose with the d16z6 in it running p28? maybe i could find one that no longer has a purpose and pop it out, then move it to the slot i need and re-wire it.?
Modified by SOHC Beast at 8:58 PM 5/17/2003
Old May 17, 2003 | 12:17 PM
TommyV's Avatar
You can run the engine w/o the vtec and oil pressure switch hooked up, you'll just get a check engine light. I wouldn't rev the engine past 5k though..
I don't believe there are any unused wires in the ecu harness that you could salvage...
And btw.. last I checked Honda doesn't sell pins of any sort. you have to buy the whole harness or pirate from another.
90Rexx
Mar 26, 2009 12:30 PM
RAK
Jan 10, 2005 11:48 AM
HeikDiesel
Oct 13, 2004 10:38 PM
Firedrake
Oct 30, 2002 04:56 AM
EGHatchy
Jul 1, 2002 07:30 AM
