machining ls rods to fit vtec pistons??
Old May 16, 2003 | 12:53 PM
philafelman's Avatar
Default machining ls rods to fit vtec pistons??
what exactly do you have to machine on the ls rods to accept vtec pistons? any help would be appreciated.
Old May 16, 2003 | 03:31 PM
notstock93's Avatar
Default Re: machining ls rods to fit vtec pistons?? (philafelman)
on b16a pistons-nothing
on "R" parts- machine the pistons (or rods) about 2mm
Oh....and SEARCH.
Old May 16, 2003 | 03:47 PM
. o 69 o .'s Avatar
Default Re: machining ls rods to fit vtec pistons?? (notstock93)
1 mm per side
Old May 16, 2003 | 03:55 PM
P1mpSlap's Avatar
Why?
GSR Rods on ebay cost like 80 bux.
Machine shop labor for that kind of work will cost you more than that.
Old May 16, 2003 | 04:25 PM
Default Re: (P1mpSlap)
well, i have both gsr rods and ls rods...the gsr ones are shorter, so i thought they wouldnt work...please let me know if they do...i was going to put my gsr pistons on the ls rods...i also have jdm sir1 b16a pistons i could use, but i read that will bump compression to 11.7:1, and i thought that would be a little high. please let me know your thoughts, obviously this is going into an ls/vtec setup, and right now i have stock valvetrain on a gsr head.
Old May 16, 2003 | 11:20 PM
. o 69 o .'s Avatar
Default Re: (philafelman)
11.7 is fine for pump gas. Use the LS rods, but be sure to add some ARP rod bolts, and balance the bottom end. Then there will be no problems reving up.
Old May 17, 2003 | 01:29 AM
tC_Dragon's Avatar
Default Re: (B16B)
yea i think 11.7 is still in the safe range...
Old May 17, 2003 | 02:30 AM
DRFlickner's Avatar
11.7:1 is a little high. I had 11:1 in my LS/VTEC and had to dial back the timing a few degrees to avoid detonation. But this is on 91 octane, you probably have better fuel in Ohio.
Old May 17, 2003 | 03:40 AM
10K2HVN's Avatar
Default Re: (DRFlickner)
11.7:1 is PERFECT!
Old May 17, 2003 | 06:01 AM
Default Re: (10K2HVN)
yeah, our gas is pretty good...i fill up with sunoco 94 octane. so do i need to shave anything off the rods for the b16 pistons? if so, what part of the rod or piston needs to be shaved?
Old May 17, 2003 | 01:24 PM
Old May 17, 2003 | 05:25 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">well, i have both gsr rods and ls rods...the gsr ones are shorter, so i thought they wouldnt work...please let me know if they do...i was going to put my gsr pistons on the ls rods...i also have jdm sir1 b16a pistons i could use, but i read that will bump compression to 11.7:1, and i thought that would be a little high. please let me know your thoughts, obviously this is going into an ls/vtec setup, and right now i have stock valvetrain on a gsr head. </TD></TR></TABLE>
GSR rods should be longer. You have to use LS rods with an LS crank, and GSR rods with a GSR crank.
LS rods are 5.394" C to C.
GSR rods are 5.433 C to C.
Old May 18, 2003 | 10:18 AM
Default Re: (b19coupe)
yeah, that was my bad, i typed it backwards. if i used the gsr crank and rods, would i lose the stroke? should i just stick with the ls rods and crank-i can get the bottom end balanced for fairly cheap.
Old May 18, 2003 | 11:12 AM
b19coupe's Avatar
LS stroke is 89 mm. GSR stroke is 87.2mm. GSR has a slightly better rod ratio, which means better for high rpm operation. It is a matter of preference, and what you have available to you, parts wise.
Old May 18, 2003 | 05:11 PM
i will probably just stick with the ls rods and crank and just get them balanced...do i need to machine the rods for the b16 pistons, or does that just go for type r pistons?
Old May 18, 2003 | 06:14 PM
b19coupe's Avatar
I don't know about B16 pistons, I have heard that no machining is necessary. If the small end of the rod fits in the piston-you are o.k. GSR/CTR/ITR pistons will not fit an LS rod without machining, for sure.
Old May 19, 2003 | 09:49 AM
so do you machine the rod or the piston??also, will that mess with the balance of the rod or the piston?
Old May 19, 2003 | 09:55 AM
b19coupe's Avatar
When I built an LS/VTEC, I had the small end of the rods machined, then balanced the rotating assembly.
BMo Tuning
Dec 7, 2008 05:06 PM
delsol456
Mar 5, 2008 05:50 PM
cazper8890
Apr 20, 2007 10:38 AM
LSTEG96
Oct 23, 2003 09:38 PM
hitekper4mance
Jul 24, 2002 04:20 PM
