Alingment/VSS
Old May 16, 2003 | 10:45 AM
crxjdm34's Avatar
Default Alingment/VSS
o.k., well i finally got my new axle in and halhshaft but, my car still shakes when taking right turns . i don't know what else to do , the only thing that i haven't done is get an alingment. can it be just that?
Second, i have a Y1 tranny w/ LSD in my CRX '91 and a PR3 ecu. my cluster doesn't work and i need to hook up my speedo cable. which cable do i use or can i wire the VSS to the ecu? i have the sensor out but it looks like there is really know way that the cable can securely stay in place???
Help!
Old May 16, 2003 | 05:30 PM
crxjdm34's Avatar
Default Re: Alingment/VSS (crxjdm34)
anyone....bump bump.
Old May 16, 2003 | 08:59 PM
SEA Hag's Avatar
You can use the mechanical VSS from a D series motor. Just it get off your old trans if its still around. It will bolt right up to a B series tranny.
Old May 16, 2003 | 09:02 PM
EvlErn69's Avatar
New User
Default Re: Alingment/VSS (SEA Hag)
you need a vss from a 92 hatch and up they dont come on the cars back then... just hit up the JY's in the area
dannyb18c
May 11, 2012 02:04 PM
sloweredcivic
May 9, 2005 09:18 AM
SpeedMonkeyRacing
Jun 2, 2004 09:40 AM
r7
Aug 18, 2002 09:41 PM
spettinger
May 22, 2002 07:58 AM
