vtec x over point in 92 GSR?
Old May 16, 2003 | 10:10 AM
crooked muffler's Avatar
Default vtec x over point in 92 GSR?
it seems to click over @ 5600 seems high...
just want to make sure of actual point.
Old May 16, 2003 | 01:39 PM
Slain's Avatar
Old May 16, 2003 | 03:27 PM
GSRwBOOST's Avatar
Default Re: vtec x over point in 92 GSR? (anti-ricecake)
4400-4500.... the iab opens around 5500-6500 depending on oil pressure etc.
Old May 16, 2003 | 04:34 PM
cleggboy's Avatar
Coupled with VTEC, you can see the GS-R engine has three stages of operation.
Stage 1 (0-4400 RPM): Low-lift cam lobe and long intake runners.
Stage 2 (4400-5800 RPM): High-lift cam lobe and long intake runners.
Stage 3 (5800+ RPM): High-lift cam lobe and short intake runners.
Old May 16, 2003 | 05:09 PM
Malice's Avatar
New User
Default Re: (cleggboy)
he's talking about a G2 integra gsr guys. last i checked they didnt have dual stage manifolds
Old May 16, 2003 | 05:33 PM
mugenracer's Avatar
Default Re: (MaliceGSR)
Gen2 GSR's do NOT have the dual runner inlet manifolds!!!!!! So you should have one x-over point which i always thought to be around 5000rpm, 5800rpm seems a little too high for that engine, but hey who am i to know????
Clegboy.....you is smokin some strange weed if you think any GSR came with 3 stage vtec...the only honda with 3 stage vtec is a JDM 1.5 civic LSi VTEC which is possibly the weakest vtec engine ever produced, it was capable of almost 50mpg and produced an amazing earth shattering "OMG I cant believe honda made this pathetic engine" 83bhp from variable valve timing/lift technology...but then again...put a banana on the market and some monkey will buy it
Modified by mugenracer at 2:46 AM 5/17/2003
Old May 18, 2003 | 07:03 PM
GSpeedR's Avatar
Default Re: (mugenracer)
Correct, G2's have 1 stage of VTEC. Cross-over is at 5600rpms, according to factory specs, but some claim it engages a little higher or lower.
ChrisSRT
Dec 22, 2007 06:13 PM
skimb37
Feb 23, 2004 09:21 PM
civickid03
Feb 1, 2004 10:12 PM
jonoknut
Sep 11, 2002 08:18 PM
JDM Accord
Aug 31, 2002 06:07 AM
