ls/vtec question
Old Jul 10, 2001 | 03:53 AM
stretracr's Avatar
Default ls/vtec question
Do you think its possible to safely rev to 8100 with the shot peened stock ls rods and arp bolts? And I emphasize safely. Thanks
Old Jul 10, 2001 | 06:21 AM
92Si's Avatar
New User
Default Re: ls/vtec question (stretracr)
As I have posted here before: I have seen LS/VTECs rev to 8100 RPM, but if you are going to take ALL of the time & money to take apart a block and build a motor from the bottom up, spend the extra $300-$600 on some aftermarket rods, since they will be the weak link of your project if untouched. Many people are going to say that the stock rods are fine, but when you have people spending $500 on a header and a thousand dollars for a set of cams, you may as well put the money into the heart of your motor and buy some rods & arp rod bolts. And of course you will have the extra strength on the bottom end and you should be able to rev out a bit higher and most likely make more power. If you do decide to stick with the stock rods, do use ARP rod bolts & get yourself a good rev-limiter.
chrisff521
May 28, 2013 11:07 AM
ej1_civic
Jan 28, 2012 10:09 PM
imskatencrzy
Sep 30, 2006 07:12 PM
Mr. Softee
Sep 11, 2003 11:53 PM
skribblah
63
Jul 11, 2003 10:29 AM
