Subs stop hitting for 1 min after long time with bass
My subs stop hitting after bumping my system for a while and they will usually turn off for about 30 sec to 1 min. I have an Alpine Type R and a Fosgate 350S. Any ideas? Thanks
Nick
Nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nOOber »</TD></TR><TR><TD CLASS="quote">Is your amp going in to protection ?</TD></TR></TABLE>
Check for a light on the amp... it usually says... "Protection" (
), but sometimes they'll say "ground" or "voltage"... pretty much just look to see if there's a light on that normally isn't.
ok, i'll take a look at the next time it happens. I dont think it would be overheating because i only put the bass **** to half and volume to like 10-12 out of 60.
carry a DMM with you so when it happens, you can check the B+, rem, and ground connections at the amp, when it is cutting out on you. this should point you in the right direction..
erikiksaz1
Audio / Security / Video
Jul 16, 2004 03:38 PM
