JDM P73 ECU physically larger?
Old May 16, 2003 | 06:24 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default JDM P73 ECU physically larger?
i have 2 P73 ecu's one is a known usdm. the other is the same size as my P28. is this jdm P73? if so does it require a CKF or the oil pressure switch? thanks again.
Old May 16, 2003 | 06:53 AM
Spade's Avatar
Default Re: JDM P73 ECU physically larger? (boostedcivicsir)
image courtsey of Katman
Old May 16, 2003 | 07:10 AM
B18C5-EH2's Avatar
Former Moderator
Loved
The JDM P73s I've seen were the same size as thew USDM P73.
The USDM P73 is an OBD2 plug and OBD2 program.
The JDM ECU is an OBD2 plug, but an OBD1 program.
I had one in my 1992 Civic with a jumnper harness for my B18C5 and it is for sure the same size as a USDM OBD2 ECU and it does indeed run an OBD1 program.
This means no extra o2 sensor, no crank fluctuation sensor, etc., etc.
KPowerSquadron
Dec 6, 2010 02:29 PM
98r860
Dec 5, 2010 06:13 AM
SOHCD16y8
Dec 27, 2008 08:19 PM
4CFED
Sep 21, 2004 11:54 AM
wuhungsixxx
Jan 16, 2002 02:07 PM
