Proper way of making H23 Vtec
Old May 15, 2003 | 05:19 PM
Forrest Gump 9's Avatar
Default Proper way of making H23 Vtec
Like the title say, what's the proper way to build a H23 Vtec? Some say all I need to do is swap out the H22 crank and rods with H23 components. Some say I need to swap out the the whole H23 short block. Some even say I can use the F22 (accord) crank and rods. Any help is greatly appreciate.
Old May 15, 2003 | 05:23 PM
Behan's Avatar
Default Re: Proper way of making H23 Vtec (94accordlx)
correct me if i'm wrong here wouldn't you take the h22 head and put it on the h23 block. am i missing something
Old May 15, 2003 | 05:33 PM
PrecisionH23a's Avatar
you'll definetely need to look into a search engine.
Old May 15, 2003 | 05:51 PM
BoostedH23a1's Avatar
Default Re: Proper way of making H23 Vtec (GudeH23a)
good thing hes new i was gonna start going ape ****
Old May 15, 2003 | 05:58 PM
optikal_blitz's Avatar
h22 head + h23 block = h23vtec.. (there's really more to it but you gotta understand the basics first)
Old May 15, 2003 | 06:44 PM
Default Re: (NatakuBlitz)
Why can't I put the H23 crank and rods into the H22 block and use the H22 piston to creat a 2.3L Vtec with 10.0 CR and don't have to worry fabricating new oil line. And if this is true, are the F22 crank and rods same as the H23 items. I'm just asking because I have the F22 engine lying around doing nothing in my garage. Thanks!!
Old May 15, 2003 | 08:37 PM
ichibanjap's Avatar
Default Re: (94accordlx)
Read through this, also ask 2point6 any questions you have, i think he's done a couple of h23vtec's. http://www.collectiveracing.ne...t=107
Old May 15, 2003 | 08:46 PM
Agent#ONE's Avatar
Default Re: (ichibanjap)
theres a 2.3 vtec motor from the factory, very rare, but would be a champion in a hatchback
Old May 15, 2003 | 09:07 PM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94accordlx &raquo;</TD></TR><TR><TD CLASS="quote">Why can't I put the H23 crank and rods into the H22 block and use the H22 piston to creat a 2.3L Vtec with 10.0 CR and don't have to worry fabricating new oil line. And if this is true, are the F22 crank and rods same as the H23 items. I'm just asking because I have the F22 engine lying around doing nothing in my garage. Thanks!!</TD></TR></TABLE> doing an H23VTEC is not the same as an LS/VTEC, you do not need to run external oil lines, all you really have to do is put an H22 head onto and H23 block, or do we have to draw you a picture
does anyone have a link to where anyone has actually told how to do an H23 VTEC, if so, PM it to me, and i will put it back in this thread, until then, this one is locked just for the fact that the H23VTEC question gets asked all the time
racerguy
Jul 25, 2016 07:00 PM
lunatics209
Jun 11, 2007 12:09 PM
h22_crx
May 7, 2007 12:41 PM
h22_crx
Mar 4, 2007 04:32 PM
GOLDBERG
May 27, 2003 09:20 AM
