gsr vs. itr tranny: what are the differences big and small?
GS-R on the left, ITR on the right. ITR also has the limited slip, 15 lb flywheel (as opposed to 18 lb on GS-R) and different clutch.
1st 3.230 3.230
2nd 1.900 2.105
3rd 1.360 1.458
4th 1.034 1.107
5th 0.787 0.848
Final Drive 4.400 4.400
Reverse 3.000 3.000
Besides that...they should be the same.
1st 3.230 3.230
2nd 1.900 2.105
3rd 1.360 1.458
4th 1.034 1.107
5th 0.787 0.848
Reverse 3.000 3.000
I think other than the gears and lsd, they're the same. GSR's also use the dual cone syncros i believe. There is a tranny guide on http://www.hondaswap.com <--excellent information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">GSR trans w/ a 4.785FD and LS 5th would be nice... and a Quaife.</TD></TR></TABLE>
Or try an R tranny w/4.7FD an LS 5th gear and a 2way Kaaz LSD!!!!
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR »</TD></TR><TR><TD CLASS="quote">
ha... itr tranny here with a ATS D20 and 4.9 final.... not so patiently waiting for my ls 5th.... damn dealer
</TD></TR></TABLE>ha... itr tranny here with a ATS D20 and 4.9 final.... not so patiently waiting for my ls 5th.... damn dealer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney »</TD></TR><TR><TD CLASS="quote">
ha... itr tranny here with a ATS D20 and 4.9 final.... not so patiently waiting for my ls 5th.... damn dealer</TD></TR></TABLE>
so NOW you go with the LS 5th huh after telling me to just get the 4.9 and let it be lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">
yep, i am a wussy.... i'll admit it. my car will not see any big tracks any more, and i am driving a lot on the highway waa waa waa
</TD></TR></TABLE>yep, i am a wussy.... i'll admit it. my car will not see any big tracks any more, and i am driving a lot on the highway waa waa waa
yep, if you have a vagina.
What is the benefit of the LS 5th gear? Is it giving you more top end or speed?
This is the first I have heard of this but I am interested!
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSpecR »</TD></TR><TR><TD CLASS="quote">What is the benefit of the LS 5th gear? Is it giving you more top end or speed?
Thanks
At high cruising speeds on the freeway, it doesn't sound like you're in a bee hive.
Thanks
I have a GSR integra. theres not a big difference between a GSR 5th and an LS 5th. But when I went with the ITR tranny, Id be in VTEC all day since it comes on at 4400 RPM in a GSR. So I just decided to get the biggest 5th gear they make.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">GSR trans w/ a 4.785FD and LS 5th would be nice... and a Quaife.</TD></TR></TABLE>Thats what I have in my gsr... minus the quaife.
Driving 40 miles each way to work... the thing already payed itself off
How long have you had this? I thought I was the first to do this.
what is the upshift like from 4th to 5th with an LS 5th gear?
an itr tranny with 4.7fd and ls fifth.... is the acceleration noticably less in 5th gear? how much lower are the revs as opposed to an itr 5th gear and 4.7 fd?
KAAZ LSD = ****, broken, crapped out after 3 months of use. junk NEVER BUY A KAAZ LSD they dont hold up worth a ****.
</TD></TR></TABLE>KAAZ LSD = ****, broken, crapped out after 3 months of use. junk NEVER BUY A KAAZ LSD they dont hold up worth a ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyBigNut1 »</TD></TR><TR><TD CLASS="quote">Thats what I have in my gsr... minus the quaife.
How long have you had this? I thought I was the first to do this.</TD></TR></TABLE>
I don't have it. I thought about it years ago.
I doubt you're the first one to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezthis »</TD></TR><TR><TD CLASS="quote">GS-R on the left, ITR on the right. ITR also has the limited slip, 15 lb flywheel (as opposed to 18 lb on GS-R) and different clutch.
1st 3.230 3.230
2nd 1.900 2.105
3rd 1.360 1.458
4th 1.034 1.107
5th 0.787 0.848
Reverse 3.000 3.000
Besides that...they should be the same.</TD></TR></TABLE>
would it be possible to put itr 2nd, 3rd, and 4th gears in a gsr tranny? if so is that a good set up?
1st 3.230 3.230
2nd 1.900 2.105
3rd 1.360 1.458
4th 1.034 1.107
5th 0.787 0.848
Reverse 3.000 3.000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">what is the upshift like from 4th to 5th with an LS 5th gear?
an itr tranny with 4.7fd and ls fifth.... is the acceleration noticably less in 5th gear? how much lower are the revs as opposed to an itr 5th gear and 4.7 fd?</TD></TR></TABLE>
well, mine will be in tomorrow night, suffice to say the car is going to fall flat on it's face with the ls 5th....
Unbeatable MPG y0!
Will you be at the double header this weekend at Nassau? Or you need to break in the tranny? Does it come with LSD?
</TD></TR></TABLE>Unbeatable MPG y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen »</TD></TR><TR><TD CLASS="quote">
Will you be at the double header this weekend at Nassau? Or you need to break in the tranny? Does it come with LSD?</TD></TR></TABLE>
neo, i will not be going to nassau,i will be at the pro solo in virginia. if i ever get the damn correct 5th gear (fuggin local acura sucks monkey *****, i should have used some of the reliable parts sources here on h-t..
) i will get the tranny back together. i rebuilt my lsd with a D20 rebuild kit from ATS. i am anxious to break it in.
