Coverting OBD 2 to OBD 1
Ok, well I tryed searching for this topic and got some results but i still have questions.
What is the name (number) of the ecu that i should use in this conversion?
I have basic bolt ons, and within a few months will have cams and springs.
Also, i have the wiring harness. Plus the ecu, is this all i need? Just plug it in and go? Do i need to mess with the distributor or anything else?
btw, i have a 98 gsr if it matters.
thanks for the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_98_gsr »</TD></TR><TR><TD CLASS="quote">ok, so if i were to get a p28, what would i need to change to make that work?
Also, what is a p28 from?
thanks again</TD></TR></TABLE>
p28 is from 92-95 civic ex/si
to make a p28 work you need to have it chipped with a dohc vtec program (skunk2, mugen, jun etc.)
or
hondata
chipped p28 being the cheaper of the two.
or
hondata
hey i got a question too, i got a 97 ls 5speed. i got a skunk2 jumper and a pr4 ls 92 ecu, my car idles normal then jumps then settles down but it does it alot anyone know what this is?? do i need to mess with the idle screw?
thanks
thanks
