Still, REAL HIGH IDLE, dont know what to do??
Old May 15, 2003 | 02:58 PM
TheHatchHog's Avatar
Default Still, REAL HIGH IDLE, dont know what to do??
I replaced all the vacume lines. No leaks, all hoses are going to the correct spots, I am getting no codes., new swap in my Dx 89 crx, its a b16a. For some reason the car is idleing at 4,000-4,500 RPMS !!! what the hell is going on....retraced wires numerous times, all correct , orrigionally I had code 14 and code 5, fixed both these problems, codes went away, now I have no codes yet it is still idleing crazy,,,,I have never driven the car with the new engine in yet.....All I want to do is figure out what the hell is going on so I could take it for a spin , and have it idle right....I tried adjusting the idle screw on the throttle body, dont know what else to do,,,,,,,anyone ever have this problem,,,what did you do....???? I switched the two outside wires on the TPS sensor so it is not that....
Old May 15, 2003 | 03:03 PM
Malgerus's Avatar
Default Re: Still, REAL HIGH IDLE, dont know what to do?? (civicciviccivic)
throttle cable too tight? Even if its only a bit too tight, it will do this. Make sure the T-body is closed at idle.
Old May 15, 2003 | 03:15 PM
Default Re: Still, REAL HIGH IDLE, dont know what to do?? (Mr. S)
The throttle does not even budge, when I start or let it sit in an idle. completely closed.....????
Old May 15, 2003 | 03:41 PM
4drEF's Avatar
Keyboard Humorist
Hmmm... maybe plug the intake to the TB? See if you are getting leaks anyplace else?
Old May 15, 2003 | 10:01 PM
Mr.S , is the man with the plan! I ****** cant believe it. I busted my *** for two -three days trying to figure out why my car is idleing at 4,000 rpms, and after all it was only my throttle cable was too tight. I knew that I wired everything correctly, it was too simple to **** up! anyway, I loosened the cable on the bracket that I fabricated, started right up, idled at about 1500, then I set the timing and idle, now i am idleing at 900, I dont know if thats where it is supposed to be, but it is running great now,,,.....
driveahonda
12
Nov 9, 2010 08:18 AM
95civic16
Jul 20, 2008 05:44 PM
99GreenEX
12
Feb 22, 2008 09:54 AM
Problemo
Jan 29, 2006 04:16 PM
mafay2
Jul 4, 2005 06:35 PM
