Mugen Pedals
Anyone with Mugen Pedals on your ITR...quick question- how did you attach the accelorator? Did you use the brackets or did you just screw it in? I was trying to interpret the instructions that are in jap and the only thing that I got out of it was that there are 3 ways and I'm not sure which is best for me. Thanks.
Also- there is only one size right?
the cover off the Accelerator? ive never seen one of those.
damn....its a good thing i just Razo's!
Not true Bob, There are 2 versions of the RAZO, one is shorter than the other and does not fit the Integra Gas pedal completely.
You should check mine out and see for yourself that it will never "slip" off!
. I bet the one that completely fits the Integra gas pedal still doesn't fit as good as the Mugen... I know that YOURS won't ever slip off, but I can't say that most people will spend as much time and put as much care into their car mods as you, so my comment was directed at them!!I already checked out your pedals, and I like them! Just not as much as I like my "nickel-chrome blown metal non-slip surface"
Get a pair of leather gloves and you can pry the top retaining tab off the gas pedal and then pull the plastic cover down. mine came off without a problem.
speaking of Mugen pedals, I have a used set from my old ITR that I have for sale if anyone is interested. make me a reasonable offer.
Daniel
Daniel
Very Interesting, I put my Mugen pedals on over a year ago and did not remove a cover for the accelerator pedal? I guess they work fine even if you don't do that?
Mattj
Mattj
Not trying to be a jerk or anything, but the last thing I want when I'm stepping on my pedals is for one of the "universal" fit pedal covers to slip off and cause problems. The Mugen's were made specifically for the Type R (and other like-sized Honda pedals), and the fit is incredibly good in comparison to all other aftermarket pedals I've seen. Always better safe than sorry...
You're not being a jerk, you're just being wrong!
The best way ive found to take the gas pedal cover off is to heat it up with a heat gun (not hair dryer) for 5-10sec on highest setting. Then itll be flexible enough to pull right off. Use a glove or rag or youll toast your hand. You should be able to re-use it. I then self-tapped the pedal in and used the bracket.
Daniel
Daniel
email me at typer98@bellsouth.net so I can get in touch w/ you
thanks
civtegra_hybrid
20
Sep 23, 2004 05:14 PM
