Stock eg hatch spoiler
Old May 15, 2003 | 11:38 AM
ricroc's Avatar
Default Stock eg hatch spoiler
Just wanted to know how to take off the stock spoiler? Is it screwed on? are the screws covered with metal plates? I'm pretty sure you know what i'm talking about. can anyone post a diagram of the procedure? thanks
Old May 15, 2003 | 11:41 AM
allmtr's Avatar
Default Re: Stock eg hatch spoiler (ricroc)
there are screws underneath im sure. im pretty sure its similar to the ek, and thats what i got. so try it
Old May 15, 2003 | 11:42 AM
andrew dc's Avatar
search is your friend...
4 bolts.. open the lid.. and get a 10 mm
easy
Old May 16, 2003 | 09:31 AM
ricroc's Avatar
Default Re: Stock eg hatch spoiler (CRX25)
Ok I know the spolier is bolted on to the window, but how do I remove the metal plate that covers those bolts? Would it be easier to take the whole window off as well?
Old May 16, 2003 | 09:45 AM
Galvatron's Avatar
you shouldn't have to remove any plate or anything. Just open the hatch window, and look up. You'll see 4 black cap nuts on the hinge bracket right under where the spoiler now is. Undo those, unplug the 3rd brake light harness, and youre done. Hope this helps.
Old May 16, 2003 | 11:59 AM
ricroc's Avatar
Default Re: (Galvatron)
OK so they're called cap nuts Anyway they're flat as well right? And there are four of them *******, but how do you take them off if there is no place to put a phillips or allen wrench? Confusing...maybe we're not on the same page, I'll post pics later...thank anyway. 1NE
Old May 16, 2003 | 12:05 PM
elwood's Avatar
Default Re: (ricroc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricroc &raquo;</TD></TR><TR><TD CLASS="quote">but how do you take them off if there is no place to put a phillips or allen wrench? </TD></TR></TABLE>
WoW! Use a 10mm socket. They are black nuts with a round top on them. Thats
why they call it a cap nut. Dont over tighten them on the re-instal.
matmcg
May 1, 2010 06:14 AM
AmbiguousCivic
Aug 1, 2007 01:14 PM
Team PHATBOYZ
Oct 4, 2005 11:49 AM
chhuong
Mar 29, 2003 06:39 AM
FlyLow
Aug 22, 2001 01:53 PM
