ZC valve cover gasket?
Really? Sorry im a ZC n00b... didnt know the older tegs were DOHC. So basically before I ask 1,000 questions will most of the parts come from the 89ish teg? Like the plug wires I asked about earlier... and now the valve cover gasket?
http://dmoore.com/crx/zc.htm#ZC Parts List
this should answer all your questions. Half way down there's a parts list
think of the zc this way....
a 86-89 teg head with a 88-91 civic/crx bottom end (minus the pistons & rods).
that should make finding parts a little easier, but you should still use one of the pages mentioned to verify what part to use as a replacement. also check my sig.
Well I dont actually need to replace it. I took the **** off and forgot to put sealer on it... DOH!
Now if I could only figure out why the car wont freakin idle anywhere close to 1k rpms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparq »</TD></TR><TR><TD CLASS="quote">
Throttle Position Sensor, or Vacuum hoses are 9/10 times the culprit for that stuff.
</TD></TR></TABLE>Throttle Position Sensor, or Vacuum hoses are 9/10 times the culprit for that stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d1crx »</TD></TR><TR><TD CLASS="quote">is it the 89 teg gaskets only work on the zc or can the stock si crx gasket go on their also? same with the spark plug seals.?</TD></TR></TABLE>
the stock crx si gasket is WAY different than the ZC gasket.
as for the spark plug seals, i don't know for sure. you might as well just get the 86-89 teg gaskets as they will fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparq »</TD></TR><TR><TD CLASS="quote">Where in the world would I get a replacement ZC valve cover gasket?
wow, not to be an ***, but you have over 6k posts... and you never saw that posted before??? j/k
</TD></TR></TABLE>wow, not to be an ***, but you have over 6k posts... and you never saw that posted before??? j/k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d1crx »</TD></TR><TR><TD CLASS="quote">are the gaskets different if you have the zc sohc? if so do i just go and ask for a 89 teg gasket for a sohc?</TD></TR></TABLE>
89 Tegs are DOHC, DOHC gaskets will not be at all the same shape as one for a SOHC. For a SOHC ZC I'd bet the 88-91 Si gasket would be the choice.
i think they are slightly different than zc valves, not positive, but i read somewhere you could make them work with slight machining.
.kyle
Aug 9, 2012 07:21 PM
