my brake pedal sinks when i stop......
Old May 14, 2003 | 11:42 PM
Tx92AccordExD's Avatar
Default my brake pedal sinks when i stop......
when im driving and step on my brakes, the pedal slowly sinks to the floor. so i have to let go of the pedal and step on the brakes again to slow down. do u guys think its the brake master cylinder?
ive just bled the brakes so i know theres no air in the system.
any suggestions to whats wrong?
Old May 15, 2003 | 12:34 AM
RastaGt1's Avatar
Default Re: my brake pedal sinks when i stop...... (Tx92AccordExD)
Mine did the same thing and it was the Mastere Cylnder. Mine was $180.00 to replace.
Old May 15, 2003 | 12:45 AM
sacredc0w69's Avatar
mine does the same thing (90 lx)
people have told me its either the master cylinder or the calipers
i got it checked by my mechanic he says all i need is to machine my rotors, and get new pads and shoes
it happens cuz ur loosing pressure, any vibration when u stop?
Old May 15, 2003 | 02:09 AM
no vibration, just the pedals sinkin to the floor.
i dont think its the caliper though.
im thinking its my master cylinder.
Old May 15, 2003 | 03:53 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tx92AccordExD &raquo;</TD></TR><TR><TD CLASS="quote">when im driving and step on my brakes, the pedal slowly sinks to the floor. so i have to let go of the pedal and step on the brakes again to slow down. do u guys think its the brake master cylinder?
any suggestions to whats wrong?</TD></TR></TABLE>
Was it doing it before you bled the brakes? Are there any leaks?
Old May 15, 2003 | 05:40 AM
Stew Pidasso's Avatar
Default Re: my brake pedal sinks when i stop...... (Chiovnidca)
Did you pump the pedal all the way to the floor when bleeding the brakes? This will loosen dirt and /or blow the MC seals out. It's most likely the MC is bad. Just double check to make sure none of the bleeders on the calipers are loose...
Old May 15, 2003 | 06:21 AM
YeuEmMaiMai's Avatar
bleed your brakes.
Old May 15, 2003 | 10:06 AM
briq4's Avatar
Default Re: my brake pedal sinks when i stop...... (YeuEmMaiMai)
Sounds like the MC do the brakes work if you hit them hard? but if you do it slowly they go to the floor?
Old May 15, 2003 | 10:16 AM
BoostedH23a1's Avatar
Default Re: my brake pedal sinks when i stop...... (briq4)
yea most likly master cylinder.. and or air inthe lines..
Old May 15, 2003 | 11:39 AM
Get a mechanic to check ur master cylinder be4 u go changing it, everyone said the same thing for me "Bleed ur brakes, check master cylinder" and such, and it turned out its just i need new pads and shoes...
go to a mechanic be4 spending $150+ on a new MC.....
let us know what it turns out 2 be...
DerekHollister
24
Sep 15, 2017 03:17 PM
uses0ap
Oct 21, 2008 11:22 AM
HASUNA91
Oct 16, 2007 09:26 AM
jpar196
Aug 2, 2007 03:27 PM
italianchooch88
Jul 17, 2007 04:33 PM
