zex kit on a b18b1
Old May 14, 2003 | 11:07 PM
B_1_8_hatch's Avatar
Default zex kit on a b18b1
my block is stock and i wouldn't mind using a zex kit with the 55-65 shot on my motor. i should be fine right as long as i don't go higher than a 65 shot?
i have the regular i/h/e and a couple of other mods. i don't race that much, just every once in awhile and i woudn't mind having a little back up in case i need it. so zex should do the trick. i usually only drive my car on the weekends and sometimes i need a little extra power when i have some peeps start messing with me.
also, should i go wet or dry kit?
Old May 14, 2003 | 11:14 PM
P1mpSlap's Avatar
Wet is better.
Why Zex? That stuff is crap.
Use NX or NOS (Holley). Much better quality selenoids and over all prodcut.
Also, I belive the ZEX kit is Vacuum/throttle based. Which is kinda gay.
The LS motor will hold a 65-75 shot just fine. If you intend to use it on the street. I suggest you look into a remote bottle opener, bottle warmer, and purge.
Also, a ignition controller that allows you to retard the timing from inside the car would be awesome.
If you seriously get into it and start spraying at the track. Look into a Nitrous Master mind controller.
Old May 14, 2003 | 11:18 PM
p1ccoloz's Avatar
Default Re: (P1mpSlap)
why do people say zex is crap? i mean its great for conservative nitrous users. i actually like the WOT activation no bottons to hit, just floor it. you'll be fine with the 65 shot, i used the 55 cause i'm chicken. i'm selling a kit if you havent already bought one, its dry.
Old May 14, 2003 | 11:35 PM
Default Re: (p1ccoloz)
acutally i'm looking for one, but i've heard the wet kits are better as well. anyway, how much are you looking for your and do you have the purge kit with it? a friend of mine is spraying a 75 shot on his stock ls and he's doing fine.
Old May 15, 2003 | 10:24 AM
Clean91B18A1's Avatar
Default Re: zex kit on a b18b1 (93hb)
I got a zex kit for sale its the dry kit w/purge and pressure gauge. Been used only for 2 weeks. Looking to get $475 shipped!
Old May 18, 2003 | 05:41 PM
97hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">Wet is better.
Why is wet better? Zex solinoild flow up to 200hp worth, i gues those aren't good enough . Been using my kit for 2 years with same solinoids so I guess they are reliable .
Old May 18, 2003 | 05:57 PM
DA-nteg's Avatar
Default Re: (97hb)
i have a 93 ls with the basic bolt on. and i am also runnin zex... been running it for 2+ years... had no problems... dry system works for me
Old May 18, 2003 | 07:19 PM
neo1z's Avatar
Default Re: (g2nosfednteg)
Zex really is the easiest kit to use for low shot applications (55-65). I personally wouldnt shoot dry to 75 shot...If you want to go that high id look more toward a wet kit.
Old May 18, 2003 | 08:07 PM
maxxdout's Avatar
please dont speak without proper knowledge. Not trying to be an a$$ but this is how inaccurate information gets around. The ZEX system is acticated based on an electric current signal. This signal is sent from the TPS or throttle position sensor located at the TB. The TPS sensor has 3 wires, ground, base signal and feedback signal. The feedback signal is tapped. The Voltage sent from the TPS when the TB is at WOT or wide open throttle , and only at WOT, is what triggers the ZEX system. At any other throttle position the voltage from the signal wire isn't as high.
I hope this clearifys anyconfusion in anyones mind as to the safety or actication of this system.
Some other systems however are mechanically acivated VIA an direct contact switch. Anything mechanical by its nature will often times fail before its electrical equivalant would, however, we can argue probability all night and still come to no conclusions.
Hope this clearified any confusion as to the activation of the ZEX system.
Old May 18, 2003 | 08:35 PM
KoRE's Avatar
Default Re: (maxxdout)
ZEX acctually offers a wet kit now.
i went with a 75 shot on my LS Auto fun times.
Old May 18, 2003 | 09:02 PM
KoRE's Avatar
Default Re: (bottlenose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlenose &raquo;</TD></TR><TR><TD CLASS="quote">go with NX, they have the same activation features. activated only at WOT and u can get an rpm module that makes it kick in only between certain rpms that u set it at. there are also other fail safes you can get from NX. personally i think its a better kit</TD></TR></TABLE>
you can do the same exact with the ZEX it's really preference but since you asked about ZEX and not NX
got with ZEX got with their wet kit and go 75. just get their colder plugs
Good Luck
teefunk01
Northeast (Sales)
Jul 17, 2007 03:51 AM
eg six
May 29, 2006 05:45 PM
jman86
Jan 11, 2006 01:30 PM
AL ASPIRATED
May 6, 2004 04:47 AM
EGkTiOn_CiViC
May 31, 2002 10:26 AM
