JDM ITR Gauge Cluster w/ 33000 km
Can anyone who's done this on a 94' GSR confirm this?? Stiffie, I understand that the newer model integras have a different gauge plugs than the older ones like mine. Have you done this before in my year vehicle??
Kong
Kong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">if it's 98 spec it will not plug and play. </TD></TR></TABLE>
that's right...
but even if it is a 98spec ... it will work w/ minor adjustments:
there are 2 options in doing this:
1) Swap out all the gauges from the JDM cluster and place it in your 94 gsr cluster base
2) Swap the film in the back of the clusters around
But keep in mind that if you want the faux CF trim from the ITR cluster, the lights may not appear correctly (e.g. the "seat belt" lights might represent the SRS... etc - this is just an example)
HTH
that's right...
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aoi-Zip »</TD></TR><TR><TD CLASS="quote">
that's right...
HTH</TD></TR></TABLE>
you can pop out the "panel" for the indicator lights and swap them.. so it'll light up properly...
any cluster questions ask me... i have done 6 teg clusters(itr, sir-g, jdm itr).. i should know this stuff
that's right...
SubTitle
Dec 28, 2003 05:22 PM
