H&R Springs with KYB-AGX shocks for my 97?
Old May 14, 2003 | 06:19 PM
rossockr's Avatar
Default H&R Springs with KYB-AGX shocks for my 97?
Would the H&R springs that drop 1.5" r/ 1.75"f be a compatible match with KYB-AGX struts? If not, what would be a better set-up? I want a mild drop, no more than 1.75. What should I expect to pay for those? Will I need a camber kit?
thanks
Old May 14, 2003 | 06:23 PM
VTEC-DA's Avatar
Default Re: H&R Springs with KYB-AGX shocks for my 97? (rossockr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rossockr &raquo;</TD></TR><TR><TD CLASS="quote">Would the H&R springs that drop 1.5" r/ 1.75"f be a compatible match with KYB-AGX struts? </TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rossockr &raquo;</TD></TR><TR><TD CLASS="quote"> If not, what would be a better set-up? </TD></TR></TABLE>
Might think about coilovers, just in case you want to raise/lower the car in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rossockr &raquo;</TD></TR><TR><TD CLASS="quote"> What should I expect to pay for those? </TD></TR></TABLE>
Around $500, depending on what kinda deals you find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rossockr &raquo;</TD></TR><TR><TD CLASS="quote"> Will I need a camber kit?</TD></TR></TABLE>
You wont NEED one, but why not put one on there? It will only help.
Old May 15, 2003 | 02:23 AM
EddieHatchBlack's Avatar
PERFECT!!!
My 97 hatch: H&R Sports, KYB AGX's (set at 2f/4r), (rear camber washer mod), alignment, Rota C8s 15" on Bridgestone Potenza Pole-Position S-03s 195-50-15, and SI rims w/ the same tires.
Cost:
H&R - $150
KYB AGX - $320
Camber thing - $2
Alignment - $50
Here's a look.
Old May 15, 2003 | 05:38 PM
rossockr's Avatar
Default Re: H&R Springs with KYB-AGX shocks for my 97? (VTEC-DA)
Thanks man, especially for the pics. I wanted to get an idea of how close that would bring me to the ground.
How hard is the install? I'm not familiar with suspension components and hesitant to start tearing things apart.
Old May 15, 2003 | 06:06 PM
VTEC-DA's Avatar
Suspension isnt that bad. Worst thing about it is getting the bolts off. You have a newer car, so it may not be as bad for you. Just make sure you have a book of somesort to help you and a decent amount of time. Its really not too hard though.
Old May 16, 2003 | 01:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rossockr &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man, especially for the pics. I wanted to get an idea of how close that would bring me to the ground.
How hard is the install? I'm not familiar with suspension components and hesitant to start tearing things apart.</TD></TR></TABLE>
No Problem.
Installation isn't that hard, you just need a spring compressor, 14/17/19mm rachets, needle nose plyers, and a alan or torx or whatever wrench, and a etc etc.
Read this installation of KYB AGXs. http://home.mpinet.net/~t-hero/Shocks.htm
I think the hardest part is just getting to the rear upper perches, becuase you either have to take out the rear speakers and get to it, or bend the whole panel forward to get to them. My brother has a 98 hatch, and we just did his this weekend. Took like 3 hours, but we had some tight *** bolts and the hardest time getting the front to line up.
Goodluck, Anymore questions? Just ask!
Modified by Eddie HatchBlack at 2:49 AM 5/16/2003
Old May 16, 2003 | 01:41 AM
Default Re: H&R Springs with KYB-AGX shocks for my 97? (Eddie HatchBlack)
Also, you might want to do the rear washer mod trick for correcting your camber. I changed my rear camber to -1 (stock spec) and my front stayed at -1.5 (-.5 more than stock spec).
Afterwards, I got an alignment, to get my toe in/out corrected. After 1 year and 10,000 miles of use, I haven't had one suspension problem and the tires wear evenly. Not all cars are the same, so good luck.
codeorange16
Suspension & Brakes
Sep 6, 2007 02:54 PM
RICKYritethere
Jun 20, 2007 12:23 PM
JerkzEm1
Suspension & Brakes
10
May 18, 2005 04:01 PM
doggydog
17
Jan 9, 2005 01:39 PM
funkee
Sep 20, 2003 02:23 PM
