Calling all you D series masters
Old May 14, 2003 | 05:24 PM
92JDMcivic's Avatar
Default Calling all you D series masters
I am wondering about the 8 black bolts on top of the cylinder head for this motor. What are they for and they are all loose on the head that i have. what is their purpose and should they be tight or loose? Also on the first cylinder, two of the valves are sticking out like a mm or 2 . how do i correct this problem. I dont know how to get a picture up but i hope someone can help me out with this problem.
DO i need to get new valves? anyone know a deal on them Thanks
Semper fi
Old May 14, 2003 | 05:45 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Calling all you D series masters (92JDMcivic)
black bolts on top with 12mm heads are for the cam caps
valves sticking out????huh?
Old May 14, 2003 | 06:36 PM
leprechan117's Avatar
Default Re: Calling all you D series masters (Emerika)
is your cam on the head??? if so then like 1/4 of the valves should be sticking out.... not just 2
Old May 14, 2003 | 06:39 PM
Spade's Avatar
like what was said before, those are the cam cap bolts. (DON"T LOSEN THEM WITHOUT A TORQUE WRENCH HANDLY)
You can host your pictures at http://www.we-todd-did-racing.com
when you go to post, either post the link or click on the Image button and insert the link between the two IMGs.
Old May 14, 2003 | 06:41 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Calling all you D series masters (leprechan117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leprechan117 &raquo;</TD></TR><TR><TD CLASS="quote">is your cam on the head??? if so then like 1/4 of the valves should be sticking out.... not just 2</TD></TR></TABLE>
ahhh.....valves are open. Yes, they will be opened is the cam is bolted in
Old May 15, 2003 | 06:58 AM
92JDMcivic's Avatar
so sohuld i tighten up the bolts for the cam? thanks for all your help
Old May 15, 2003 | 07:07 AM
Spade's Avatar
Default Re: (92JDMcivic)
According to specs. YOu need to get a picture shared first! So that we can truly verifiy what we think your describing.
See my post above for directions on how to do it.
Accordian47
K Series
Aug 21, 2015 01:52 PM
shm91
Nov 15, 2013 08:55 PM
r.etheridge
11
Dec 6, 2010 01:42 PM
Mugen112
Sep 14, 2006 11:06 AM
92JDMcivic
May 14, 2003 05:05 AM
