mini me wiring question......please help
Old May 14, 2003 | 04:58 PM
gocivicgo's Avatar
Default mini me wiring question......please help
Ok, might go with a mini me on my 88 CRX Si. FIrst of all i will list what im going to do then ill ask my wiring question and heres hoping i can get some help.
D16a6 block
D16y8 head
D16Z6 intake
P28 ECU
Now my question is, one is this a good setup??
And number 2 how would i wire this into my 88 SI?
Do i use my SI harness?, or the z6 harness?? OR a conversion harness?? OR what , OR is there a better way to run this setup?? Would i be better with a Z6 head?? or a y8 intake manifold? please help.....
Old May 14, 2003 | 05:07 PM
Timmah!!'s Avatar
Default Re: mini me wiring question......please help (gocivicgo)
These links should help you out a abit
http://www.geocities.com/chipm....html
http://crx.honda-perf.org/arti....html
All the info is there.Most of it is real straight forward
Old May 14, 2003 | 05:17 PM
MrTodd's Avatar
Default Re: mini me wiring question......please help (azroth)
Also a note: Don't use the P28 ECU for the Y8 head. The VTEC lobe is radically different between the Z6 and Y8 head. The P28 ECU's VTEC fuel map is not sufficient for the Y8 VTEC lobe, and the x-over point is too early at 4800 RPMS. The stock Y8 VTEC x-over is 5500 RPMS.
IMHO, if don't want to spend the money investing in a V-AFC, or learn/understand how to use ghettodyne, then go after a Z6 head. It will provide better results if you want to go with the cheaper/less hassle route.
Old May 14, 2003 | 05:20 PM
gocivicgo's Avatar
Default Re: mini me wiring question......please help (MrTodd)
Alright Z6 head and p28 but i still have no idea how to wire it up in my crx??
Old May 14, 2003 | 05:23 PM
MrTodd's Avatar
Look into OBD-0 to OBD-1 conversion's. There are a few guys in this forum that will sell you a nice ECU conversion harness - after that, you'll just need to re-wire the distributor, and modify the injector harness (only if you wish to use OBD-1 injectors, I would stick with the stock OBD-0's).
Just ask around, and I'm sure some people will hook you up with information/links that relate to the conversion.
Good Luck!
Ej1_Lipe
17
Jan 19, 2011 03:25 PM
asianrepnsb
Mar 3, 2008 01:20 PM
GReddyTurboCoupe
Apr 27, 2005 10:35 AM
crx_of_fury
Dec 23, 2004 04:44 PM
I8ayellowcrayon
Aug 13, 2003 09:24 PM
