Bad grounds..any suggestion
Old May 14, 2003 | 04:45 PM
PoonHunter's Avatar
Default Bad grounds..any suggestion
Ok I have a bad ground somewhere on my brake lights/ horn harness. Anyone can tell me maybe some grounds I could check..any pics would be helpful. Thanks in advance
Old May 14, 2003 | 09:25 PM
PoonHunter's Avatar
Default Re: Bad grounds..any suggestion (PoonHunter)
ttt
Old May 15, 2003 | 12:06 PM
brent_G's Avatar
in my crx i had a bad ground problem like that...it was causing my running lights not to work...but behind the cluster there is part of the harness...it was being pinched between the daash and the metal frame back there...it was a red wire toucing the frame causing it to instantly blow a fuse...
also check the ground in the back...there should be a screw that wires go to in the center that grounds out the tail lights...also check and see if there are any wires behind your radio that could be causing this to happen....its the most frustrating thing tryign to find a bad ground...took me about 15 hours a messing around with wires on my car to figure out it was a small wire behindi my cluster...
i dunno check some of those things and see if that helps...if not i have a fuse box that wasnt the problem for me. Wires are a bitch...
Old May 15, 2003 | 05:53 PM
PoonHunter's Avatar
Default Re: Bad grounds..any suggestion (screamincivik)
yeh its frustrating. I checked behind the tails. Im gonna check out my radio and non stock wiring. thanx for replying
Old May 15, 2003 | 06:50 PM
USDM 4G VTEC's Avatar
i would say
go and look all around the harness......
whenever u see some cable going into gnd..... take it off,,, grind it to bare metal. clean it and put it back in..... u will be surprised that any baad gnd can cause problems...
Old May 15, 2003 | 09:23 PM
brent_G's Avatar
Default Re: Bad grounds..any suggestion (USDM 4G VTEC)
also when i had my eg hatch i had a wire problem once that acted like it was my main relay. But it was the simplest thing...there was a ground attached to one of the nuts holding my fuse box in place that messed EVERYTHING UP...i mean i couldnt even turn my car over....its always something so dumb like that...
look for the obvious
FTNW
Jan 23, 2011 11:54 AM
choua01
Aug 17, 2010 01:30 PM
knick08
Oct 18, 2007 12:22 PM
1000_miles
Nov 4, 2006 11:02 PM
hydroflip
Feb 28, 2002 07:50 AM
