JDM front bulbs
Did a HT search and found a list of bulbs to get for the JDM front. However, I wondering which of the ones I have already will work.
As of right now I have Sylvania bulbs from the local Pep Boys. These are the ones I have:
-2357A/says replaces 2357NA - 12 volts
wondering if they will work for the turn signals
-H4 Halogen - 12 volts, 60/55 watts
wondering if they will work for the high beams
-H1 Halogen - 12 volts, 55 watts
wondering if they will work for the fogs
-194LL (long life - supposedly 2x the life) - 12 volts
OR
-168 - 12 volts
wondering if they will work for the sidemarkers
Jon
Modified by TypeR1558 at 6:43 PM 5/14/2003
OR
-168 - 12 volts
Jon
9005 hi
1157 corner
These are the only ones I don't have. I am guessing the 1157 is a single filament, whereas the one I got is a dual filament bulb. If so, will the dual filament bulb run? Does having a single/dual filament bulb have only affect WHEN the light will be on? I would like to set it up so that the corner lights stay off, but blink when I signal.
Jon
1157 corner
Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR882 »</TD></TR><TR><TD CLASS="quote">low beam = 9006
high beam = H1
city light = 168
fog = H3
corner = 1156</TD></TR></TABLE>
I was referring to this.
high beam = H1
city light = 168
fog = H3
low beam = 9006
high beam = H1
city light = 168
fog = H3
corner = 1156
OK, well.. im thinkin that multiple bulbs are able to work for each application. Anyone found others to work in any of the slots? Which of the ones I have will definitely NOT work where I listed in the original post. Because so far there are 2 different lists of bulbs for the jdm front.
high beam = H1
city light = 168
fog = H3
corner = 1156
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">
I was referring to this. </TD></TR></TABLE>
errrrrrrrrrrrrrrrrrrrnt.
the 194s and 1157's work.
168/194 are interchangeable.
1156/1157 are interchangeable.
Den, go back to mommy so she can own you again with a restriction
Yes they work but what has that to do with anything.
I'm using 194 for my usdm front and you can use them for your jdm front too. Same bulb that goes into the cluster.
u can find most of the bulbs at your local honda/acura dealer. they are cheap too. i got all my bulbs for 30 bucks. just ask your dealer for thoughs bulb and they will hook it up!! only good experience i have had at the dealership was when i bought these bulbs
Edit: the H3 bulb u need is a flat connector its not round.
