Error Codes on OBD0 - OBD1 Conversion???
I'm thinking about converting from OBD0 - OBD1, but my main question is how do I read any error codes if the OBD1 ECu doesn't have a LED blinker on it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicEF9 »</TD></TR><TR><TD CLASS="quote">I'm thinking about converting from OBD0 - OBD1, but my main question is how do I read any error codes if the OBD1 ECu doesn't have a LED blinker on it?
Ground D4 on the ECU. It will cause your CEL to flash in your instrument cluster.
</TD></TR></TABLE>Ground D4 on the ECU. It will cause your CEL to flash in your instrument cluster.
You jumper the connector under the hood on the passenger side shock tower - the one that you're supposed to jump when you're checking timing.
yeegsr
15
Apr 3, 2006 06:36 PM
