T1R Lightweight Battery
Old May 14, 2003 | 10:54 AM
skafia's Avatar
25 Year Member
Default T1R Lightweight Battery
jdmhondaparts.com - doesn't have any in stock and they didn't sound too enthusiastic about ordering any either
randdmotorsports.com - special order, $155 + 25 shipping
jdmspecperf.com - doesn't carry it
aj-racing.com - getting some within two weeks, $150 + shipping (from canada, yikes!)
ipsracing - god damnit mike, answer your phone! LOL
Old May 14, 2003 | 10:56 AM
Asahi's Avatar
Default Re: T1R Lightweight Battery (skafia)
Odyssey PC625 is 13.5 lbs and $99. http://www.batteriesplus.com
Trey
Old May 14, 2003 | 11:03 AM
Dirt's Avatar
Default Re: T1R Lightweight Battery (Asahi)
Even cheaper. . . http://www.batteries4everythin...eries
Old May 14, 2003 | 11:06 AM
JDM CTR '00's Avatar
T1R Light weight Battery: 165 picked up
Old May 14, 2003 | 11:11 AM
Asahi's Avatar
Default Re: T1R Lightweight Battery (BrewCityR)
Great find Double A ron!
BTW I have used the PC625 for a year and through winter with no problem so far. It is obvious it doens't car for temperatures in the Teens. Opt for the PC680 if you live somewhere really cold.
Old May 14, 2003 | 11:27 AM
skafia's Avatar
25 Year Member
The T1R racing battery is made for automobiles. These battieries are for jetskis and ****, no difference?
Old May 14, 2003 | 11:30 AM
Chris N's Avatar
As long as it has the same voltage/capacity/etc as a battery labeled for automotive use, it shouldn't matter one bit.
Old May 14, 2003 | 11:32 AM
Asahi's Avatar
Default Re: T1R Lightweight Battery (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">As long as it has the same voltage/capacity/etc as a battery labeled for automotive use, it shouldn't matter one bit.</TD></TR></TABLE>
These have lower than standard power output but i don't know the weight or power (CCA) output to a T1R. Someone have that info?
There has been no issue with the amount of power it provides and as for operation it is the same as anything else.
Old May 14, 2003 | 11:33 AM
RTW DC2R's Avatar
for the record...my T1R battery sucks and has been sent back to the manufacturer.
Old May 14, 2003 | 11:38 AM
B2FiNiTY's Avatar
Default Re: T1R Lightweight Battery (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">for the record...my T1R battery sucks and has been sent back to the manufacturer. </TD></TR></TABLE>
Care to explain?
Flux's Avatar
Can you please be more specific. A comment with out info is useless to us really.
Old May 14, 2003 | 12:31 PM
Mike M's Avatar
Founding Member
He had his Battery for a month or two, installed it into his car, and the battery was not holding a charge, he sent it back to me we sent it to A&J and its being tested to see if its covered under warranty.
I fail to see why you would simply Generalize that All the batteries suck because yours had problems. Haven't had any other people having a problem with theirs.
Old May 14, 2003 | 12:44 PM
BlueR's Avatar
Default Re: T1R Lightweight Battery (Mike M)
my T1R sat for 4 weeks after i returned from the expo...
started up my car last week on the first crank
Old May 14, 2003 | 12:47 PM
RTW DC2R's Avatar
Sorry to generalize, just frustrated with that situation. Im sure the battery is fine in most cases.
To explain my problem with the T1R, the battery was NEVER INSTALLED on the car, mainly because the car was still being built at the time. When the time came to finally get my car up and running, the stock battery was hurting and struggled to turn over the motor. So I went to install the T1R battery after it had been sitting in my room for quite some time(not sure how long, probably over 2 months), and I got nothing, just some buzzing noise and the car wouldnt even turn over. I put the battery on from my civic, and it atleast tried to turn over, so I figured the T1R battery was drained. No problem, Ill just charge it up. Took the battery to a local station to charge it up, went to install it, it started the car up no problem. Next day, battery was dead. This was not good because the car was to be tuned that day. Not a big problem, I figured Id just take the battery with me to the tuning shop and they could charge it up while getting my car ready. I used a temp battery at the shop, got the car running halfway decent, went to put in the T1R, and got more buzzing. So thats when I got in touch with Mike M to see if we could get it straightened out. I sent the battery back, and am waiting for word.
Old May 14, 2003 | 12:57 PM
Todd00's Avatar
I said I don't want a title!
Meijer or any friendly garden store...
320CCA tractor battery. Half the size/weight of stock, plenty of CCAs to crank over a Honda motor and it is only $19.99
Been running it for well over a year in my R with no problems. And if it dies, I'm only out $19.99. I could buy 8 for the price of one T1R.
Or, Honda Goldwing battery. 410CCA and it is about $50.
Just throwing out some other options.
Old May 14, 2003 | 01:10 PM
JeffS's Avatar
http://www.stealth316.com/2-dynabatt.htm
Good reading with some links.
Old May 14, 2003 | 01:13 PM
.RJ's Avatar
.RJ
Default Re: T1R Lightweight Battery (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Meijer or any friendly garden store...
Just throwing out some other options.</TD></TR></TABLE>
These legal for SCCA STX autocross?
Old May 14, 2003 | 01:14 PM
Todd00's Avatar
Default Re: T1R Lightweight Battery (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
These legal for SCCA STX autocross?</TD></TR></TABLE>
They are legal for stock. As long as the battery is the same voltage.
Old May 14, 2003 | 01:21 PM
MackSpeed-616's Avatar
320CCA tractor battery. Half the size/weight of stock, plenty of CCAs to crank over a Honda motor and it is only $19.99</TD></TR></TABLE>
this defeats the point. guys who want the t1r do it for image.
i dont think a garden tractor battery can drop the panties like some jdm bling bling y0 tiiite boyee battery. jeeez
Old May 14, 2003 | 02:00 PM
skafia's Avatar
25 Year Member
Default Re: T1R Lightweight Battery (BustaNutt-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 &raquo;</TD></TR><TR><TD CLASS="quote">
i dont think a garden tractor battery can drop the panties like some jdm bling bling y0 tiiite boyee battery. jeeez </TD></TR></TABLE>
Hell yeah I'm all about the bling. If I didn't care, i'd buy a CRX and throw a motor into it, but that's why I'm rolling in an R
btw - take your jdm bashing *** outta this thread, you serve no purpose.
Old May 14, 2003 | 06:36 PM
Floyd's Avatar
lots of info in here.
Old May 15, 2003 | 04:31 AM
JCushing's Avatar
Default Re: T1R Lightweight Battery (Floyd)
i bought the hawker genesis G13EP from portablepowersystems.com
it weighs in at 10.8 lbs starts my car up everytime even in this last cold winter we had here in massachusetts..
http://www.gotbatteries.com/pr...r.htm
Old May 15, 2003 | 05:13 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: T1R Lightweight Battery (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">i bought the hawker genesis G13EP from
it weighs in at 10.8 lbs starts my car up everytime even in this last cold winter we had here in massachusetts..</TD></TR></TABLE>
good choice. i use the same battery. believe it or not, it has 360 cca! also, the stock battery is 31lbs, the hawker is 10.78
i might be able to get these batteries if anyone is interested. :-)
Old May 15, 2003 | 05:27 AM
JCushing's Avatar
Default Re: T1R Lightweight Battery (rodney)
wow, yours loks alot prettier than mine.. i used spacers on the stock tie downs and to stock battery holder to hold mine down....
i also just used the bolts the battery came with and put on terminals on the wires..
Old May 15, 2003 | 05:42 AM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">wow, yours loks alot prettier than mine.. </TD></TR></TABLE>
lol, thanks.... i bought some strap aluminum from home depot, shortened the stock J bolts, and bought the terminal kit from http://www.batterymart.com. i swap batteries for winter use, just so i can run the lightest battery feasable for race season.
